Relieving Hydraulic Pressure Question !
/ Relieving Hydraulic Pressure Question ! #1
KiotiKevin
Port Morien, N.S., Canada
Kioti NX4510
When I turn my tractor off, I leave my loader and my rear implement raised. After it shuts down, then I lower both of them to the ground (I am assuming) to relieve the pressure off of the lines and pump ??
Question - if I lower my loader and or implement to the ground before I shut the engine off creating pressure in particular to the loader, could it cause undue pressure/stress to the lines or pump or will the pressure gradually release on its own.
Reason for asking is , my brother-in-law pulled my tractor out of the garage and I asked him not to lower the loader or snow blower to the ground untill he shut the engine off - he said not to be so silly, that wont hurt anything and he should know because he drove a fork lift for 20 years.
If he is right, that's ok but if he is wrong could you please explain exactly why in mechanical terms so I can tell him.
Thanks
Kevin
/ Relieving Hydraulic Pressure Question ! #2
Virtually all cut and scut 3pt lifts are power up, and gravity down.. as in .. no down pressure. Lower them to the ground any time you like.. no effect on the pump.. etc.
Most modern loader will have down pressure, and lots of peopl use the bucket curl to even raise the front end to sset jack stands under the tractor to change tires. No problem to the pump.
Remember.. the weakest link in your hyd system SHOULD be the relief valve... not the pump or the lines. If you were overtaxing the loader by lifting the front.. the relief would pop.
Relax.. you aren't hurting the tractor by dropping your implements while it is turned on..
Soundguy
Thanks Chris,
My main concern is after it is shut off with leaving the pressure on the loader while it is sitting until the next time I use it.
Kevin
/ Relieving Hydraulic Pressure Question ! #4
</font><font color="blue" class="small">( Thanks Chris,
Kevin )</font>
if I remember correctly, the loader manual states that you should not move the loader without the engine running. I have no idea why they state that, as they don't explain their rationale.
One thing though, it's always best to lower all implements to the ground when you're not using the tractor. This is for safety reasons. One never knows when a hydraulic line may burst and the raised implement could cause someone harm if they're near enough to it when it happens to fall.
You do no harm at all lowering the unit to the ground and then shutting off as Chris has said. John
/ Relieving Hydraulic Pressure Question ! #5
Simple static weight pressure setting on the spools and pump is nothing compaired to the dynamic pressures it sees in operation. Don't be concerned if it leaks down either.. many spools are metal on metal. For safety.. you should drop all hyds anyway.
KJ; I think they say not to operate the laoder with engine off in case you pin someone or something.. then have no way to pic the laoder back up.. etc.
Soundguy
/ Relieving Hydraulic Pressure Question ! #6
If you're only concerned about the pressure remaining in the lines after the engine is off, you can lower before or after killing the engine. Then with no power move your joystick to open/close valves for various FEL functions. This will relieve pressure in the lines.
/ Relieving Hydraulic Pressure Question ! #7
</font><font color="blue" class="small">( My main concern is after it is shut off with leaving the pressure on the loader while it is sitting )</font>
Just my personal habits, but I always lowered 3-point implements all the way before killing the engine. I'd also lower the FEL to the floor or ground, then kill the engine, and lastly, move the joystick in all directions to relieve any hydraulic pressure, not because of any concern about damaging the tractor, but just to be sure everything would be in exactly the same place I left them; i.e., no settling or movement of anything while parked.
/ Relieving Hydraulic Pressure Question ! #8
I always move my joystick around to relieve the prssure. I always do this after the motor is shut down. This is for the FEL. As far as the 3 point I will lower it also if there is an attachment on it. Otherwise I never worry about it.
murph
/ Relieving Hydraulic Pressure Question ! #9
</font><font color="blue" class="small">( ..not to operate the laoder with engine off in case you pin someone or something.. then have no way to pic the laoder back up.. etc.
Soundguy )</font>
This one I will remember as part of safe operating practice.
Thanks
/ Relieving Hydraulic Pressure Question ! #10
Kevin,
The hard part is admitting that brother-in-law was right! /forums/images/graemlins/grin.gif
TK
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
1993 EAST 102" X 48' SPREAD AXLE FLATBED TRAILER (A64276)
1993 EAST 102" X...
2021 Dodge Durango SUV (A61574)
2021 Dodge Durango...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
Used Landpride GR1525 Stump Grinder
Used Landpride...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
