Releasing Pressure to hook up attachments
   / Releasing Pressure to hook up attachments #11
Have you seen this work over a wide range? Sure the pressure is equal, but if it is high then you would still have trouble getting them apart, IMHO.
Bob.
I believe there is a difference when separating QD's that are connected together from an attachments for this reason. If the QD's are connected together, and the heat has expanded the fluid and increased the pressure, the pressure is pushing on the poppet/balls , and when you pull the sleeve back, the small bearings around the sleeve should almost spring out and the coupling release.
When you are trying to couple, you have to push against the poppet/balls which have pressure built up behind them. Tapping or pushing on just one usually enough to release the pressure. Some of my couplings have a two way sleeve. You can push or pull the sleeve to connect.
   / Releasing Pressure to hook up attachments #12
Bob.
That sounds reasonable J_J. At this point I am only having a problem about once a year. Just releasing the pressure with a hammer and pin is easy enough. I keep them in my on PT tool box.
   / Releasing Pressure to hook up attachments #13
I used to use the hammer and pin method until I figured out an easier way. This is so simple your going to wonder why you didn't think of it. I wonder why it took me so long. Right next to the QD's on the loader is the bottom end of that level indicator rod that I never used. And it's just the right size to slip the female disconnect over. I do that and then grasp the disconnect tightly with one hand. Than hit that hand firmly with the heel of the other hand( not so hard that it hurts). Works 95% of the time. I usually grab it with a rag to keep the oil from squirting all over.
   / Releasing Pressure to hook up attachments #14
I don't think the 422/425 has that rod. I had actually thought about welding a rod to the PT for this purpose. Actually putting a clamp around the roll over tube with a bolt sticking out might work. I don't like to weld to the PT itself.
Just a silly rule. I have got to think about this one.
   / Releasing Pressure to hook up attachments #15
If you take the male QD and push it against any metal surface, it should release. Put a rag around it to absorb fluid.
   / Releasing Pressure to hook up attachments #16
All my attachment side qd's are female. you got to stick something in their to relieve the pressure.
   / Releasing Pressure to hook up attachments #17
Well, you could switch one of the QD's so you have a male and a female QD on each attachment. That will also let you plug the QD's on the attachments together. I believe it is normal for the male QD on the hyd supply to be pressure, and the female QD the return. This would also alleviate any hyd motor connections problems.
   / Releasing Pressure to hook up attachments #18
Like several others, I have swapped my quick-connects so each item has a male and a female. When an unused implement with it's hoses connected together sits in the sun, the heat sometimes builds enough pressure that I have to use tools to separate them. I can usually just use a pair of pliers to twist and pull the sleeve. I don't think there is any way around the problem other than adding in a bleeder valve of some sort.
   / Releasing Pressure to hook up attachments #19
I'm surprised at you guys having female QDs on your implements. On my JD it's the other way round, all female on the tractor and all male on implements. So that they can easily be bled by pressing on a metal surface. This is often necessary, especially with the loader or the MMM because of their weight pressing on the cylinders.
   / Releasing Pressure to hook up attachments #20
Well, that's one of the things about Power-Trac. They don't much care how the others do it. They do things the way that suits them - like being closed the week of Thanksgiving just when I need a steering hose that the local hose guy can't duplicate (grrr).
Seriously, I think they make a lot of their basic engineering decisions based on what works for their other machines in the coal mines. Conditions half a mile under an Appalachian mountain... well, priorities are kinda different there. Temperatures don't swing very fast, but having a machine that's dirt simple might count for a lot.
My job takes me to coal country about once a week. I've never been farther into a mine than 100 feet into an adit, but I can tell you for sure that priorities are *really* different there. (I've never seen so many ambulance services until I went there.)
Power-Tracs are derived from deep mining equipment, so the approach is radically different from machines that are based on wheat-farming tractors from Lake Wobegon or industrial loaders from a gravel quarry.
It's a completely different world. I still don't really understand it.
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2006 Mac Truck CXN613 (A56438)
2006 Mac Truck...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
