Redneck tractor starter
/ Redneck tractor starter #2
That looked like they had practiced a bit, I noticed that she did not let the clutch out until the strap was completely unwound from the slip clutch.
/ Redneck tractor starter #3
Just seeing a woman in the seat makes me nervous.
Never met one that could operate safely.
I'm sure that they are out there.....just not lucky enough to cross paths yet.
/ Redneck tractor starter #4
The tractor has a manual transmission, exactly why cant it be jump started? Don't think I would want to do that, but if your stuck.
I didn't get that either. I think he was trying to say this method could work in the event the loader and blade/cutter were down. I think it is better to just fix the problem. But, we have all been in the situation where we needed the tractor to start ONE more time...
/ Redneck tractor starter #6
All I can say is foolish. I pride myself on being a redneck (that is a compliment here in Alabama) and I would run the other way if I ever saw someone attempting that.
/ Redneck tractor starter #7
Many moons ago my dad had a seemingly big Allis Chalmers with the hand crank in front. In the winter in Wisconsin it was very difficult to start.
He took a driveshaft of some sort and made a fitting to hook onto the cranking extension in front. Then he jacked up the rear of the family car and hooked the other end to the rear wheel somehow. He started it that way using the car a few times, but it sure was a lot of work.
Necessity is the mother for red neck inventions.
/ Redneck tractor starter #8
wouldn't work on my NH without some safeties being disabled.. Mine won't start with the PTO engaged even with the clutch pushed in unless that's just a electric start issue?
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
2010 FREIGHTLINER FLD120 SD (A65643)
2010 FREIGHTLINER...
2021 BOBCAT E50 R2 SERIES EXCAVATOR (A63276)
2021 BOBCAT E50 R2...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
