Redneck tractor starter
/ Redneck tractor starter #2
That looked like they had practiced a bit, I noticed that she did not let the clutch out until the strap was completely unwound from the slip clutch.
/ Redneck tractor starter #3
Just seeing a woman in the seat makes me nervous.
Never met one that could operate safely.
I'm sure that they are out there.....just not lucky enough to cross paths yet.
/ Redneck tractor starter #4
The tractor has a manual transmission, exactly why cant it be jump started? Don't think I would want to do that, but if your stuck.
I didn't get that either. I think he was trying to say this method could work in the event the loader and blade/cutter were down. I think it is better to just fix the problem. But, we have all been in the situation where we needed the tractor to start ONE more time...
/ Redneck tractor starter #6
All I can say is foolish. I pride myself on being a redneck (that is a compliment here in Alabama) and I would run the other way if I ever saw someone attempting that.
/ Redneck tractor starter #7
Many moons ago my dad had a seemingly big Allis Chalmers with the hand crank in front. In the winter in Wisconsin it was very difficult to start.
He took a driveshaft of some sort and made a fitting to hook onto the cranking extension in front. Then he jacked up the rear of the family car and hooked the other end to the rear wheel somehow. He started it that way using the car a few times, but it sure was a lot of work.
Necessity is the mother for red neck inventions.
/ Redneck tractor starter #8
wouldn't work on my NH without some safeties being disabled.. Mine won't start with the PTO engaged even with the clutch pushed in unless that's just a electric start issue?
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A64553)
2018 Caterpillar...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
2012 KENWORTH T370 CAB & CHASSIS (A65643)
2012 KENWORTH T370...
2011 BRENNER TANK 200BBL CRUDE TANKER (A65643)
2011 BRENNER TANK...
