Redneck pool heater 3.0
   / Redneck pool heater 3.0 #41
Here is mine. It will heat the in ground pool to over 90 if I put the cover on at night. Without cover it will get to about 80 or 85. It needs some weed control.
Don't want to hijack the thread, but maybe some details on this? How did you get it coiled so nicely? I'm fixing to make some sort of solar heater using poly hooking into my DC pool pump once I get it hooked to own solar supply so basically it will pump whenever the sun is shining. Once I get it going, I'll be posting as well.
David Sent from my iPad Air using TractorByNet
   / Redneck pool heater 3.0 #42
Back in the late '70's , In High School , We built 8' x 4' solar water heaters . Started by making the 4' x 8' frame out of 2 x 6's . On Back of frame We added 2 sheets of Galvanized metal roofing , that was flattened on ends and 1 side , thus it would nail flat on the edges of the frame . In the middle , we drilled and riveted the 2 sheets together down the entire length .
Next step was to paint entire inside of frame and roofing with Flat Black paint . Not quite sure what size copper tubing We used , 1/4" , maybe 3/8" ??? But it started by coming through 1 corner , running all the way to other end of frame in the first valley . Then it was gently bent over the peak to the next valley and ran all the way back down to the other end of frame . This continued all the way across , were is was fed back out of frame to were ever the project was . After the tubing was finished , We experimented with covering the frame with every thing from a Heavy Thickness Clear Plastic film , to a thin plexiglass sheet to donated single pane glass from old windows . The glass was not a continuous sheet , think We ended up with like 4 pieces of glass to cover 1 frame .
Depending on flow , angle of panel in relation to sun , daylight hours , etc.. Most of the people , Who used them in pools were actually using their pools any were from 2 months early up to 3.5 months early , ( normally , around here , mid June is about time a pool will get warm enough to use with out any
aid ) .
Can't remember any kind of temp's or as I said earlier , the copper tube size , But do remember they were very effective , But also can't remember which was the most effective . Best Value was the donated glass or the plastic film . Plexi was $$$ back then and all though glass was donated , it was a pain to deal with , as We had to set a strip of wood all the way around inside frame to lay glass on , then another on top the glass to hold it in .
Fred H.
Got it up to 29 last night... but lost 2 down to 27 overnight. I decided it was better to let the fire die off before bed and stop the water flowing, then have the fire die overnight and keep pumping water through 160'+ of garden hose in 14 deg air, effectively cooling the water.
Supposed to be nice today... and may very well be the last day for the pool. We're chewing through wood pretty good... unless we get a warm spell, or I get the oil system working better.
31deg BABY!!! :) There is no hesitation... you just walk in. Not cold, not hot. Just right. I couldn't be happier with it.
   / Redneck pool heater 3.0 #45
Congratulations. ..
Maybe you will be able to have a Thanksgiving pool party this year? :D
   / Redneck pool heater 3.0 #46
Ah, brings back memories... in the 70's, a buddy had a stainless steel tank, maybe 5' x 8' x 4' deep. Open on top, and a bench was installed along both sides. This sat outside, and was heated with a wood stove with makeshift copper coils, and a small cultivator pump.
Imagine a very cold, clear Indiana night in the middle of the winter, lots of snow and ice on the ground, and a dozen naked hippies enjoying a hot tub- the water was 110 degrees, if I remember, which was plenty hot. Snow was falling on our heads, but we were overheating. Two red-hot guys decided to go over the hedge and go sliding on the icy street- run and slide on your (bare) feet. Naked. They were having a great time, with some of us watching from over the hedge top, when a car turned onto the otherwise deserted neighborhood street. A cop car. They ran, fortunately not into our yard, and the cops spent 10 minutes cruising up and down the street looking for them. Too cold to get out of their cruiser, mind you. The two guys weren't overheated when they finally made it back into the tub.
LOL, good story!
Got up to 32 yesterday, but down to 28 this am. Still pretty good. Supposed to be a nice couple days.
   / Redneck pool heater 3.0 #48
Now, I think you need a good way to insulate the pool itself. You've shown that you have a good heating system, but there will still be lots of heat escaping from the pool (mostly the water surface, but the sides, and maybe the bottom, too).
We did end up getting a solar blanket, and I think it's making a big difference. We seem to have leveled off to 28deg without me putting any more heat into it since the weekend. This is with mid-teen temps overnight, but nice sunny days in the mid to high 20s.
I don't think insulating the pool would be practical. I don't think I'd loose much in the ground, the solar blanket helps, and the sides... well it is what it is. It seems with so much water it takes a long time to heat, but also for it to cool off. I think it's safe to say that with this heater I've doubled the pool season.
Found something pretty cool on the web; a smudge pot. Perhaps my next pool heating project! :)
...however, I did plan to buy more sand for the pad... maybe I'll see what styrafoam would cost vrs that. Easy on the feet and insulation.
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
Demco 365 Gravity Wagon (A50775)
Demco 365 Gravity...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2013 Cadillac SRX SUV (A55758)
2013 Cadillac SRX...
