Red Torin 20 ton shop press mod
   / Red Torin 20 ton shop press mod
What you've done so far looks good. I thought you were going to get a different jack though? Why go through making the base for this one if your getting a diff one? Or that thought has passed?
Lol Sorry I didn't post the original jack; probably should have. I will post the original manual jack with the new air/hydraulic jack. Will also post progress pics tonight Sorry for any confusion I may have caused
   / Red Torin 20 ton shop press mod #12
Didn't confuse me, I saw the new jack in the first pictures! :D
   / Red Torin 20 ton shop press mod #13
haha my bad.. I saw the "manual" handle receiver in one of the zoomed in pics.. Didn't realize there was more! And also I guess didn't realize that air over hydraulic still has manual use if air isn't there...
Well got the plate done and primed.
Gotta admit I should not have welded the inside edge (I knew this and did it anyway) as the jack did not sit on the plate as the weld caused interference.
Nothing a little grinding couldn't fix...
Will paint black tomorrow after the primer cures.
Will post pics of the completed product.
Here is the finished jack/u-channel plate.
My next step is to make some type of platform to raise the press up 8-12" and have it mobile on casters.
Wood or steel for this platform?
   / Red Torin 20 ton shop press mod #16
Either will work beautifully. Any material in stock? I always tend to lean that way... Someone made a good point earlier though, that the wood deck is a much better dampener if it comes to an "oopsy"...
Have some angle and 1-1/2" square tubing that I can use so I may use a combo of steel frame and plywood deck.
   / Red Torin 20 ton shop press mod #18
Nice work. On my home made press I just cut off a 3/8" ring of pipe the top of the screw fit into & tacked it in place. I slide the jack under it, a few twists & it is secured in place. I love may air over hydraulic jack! Just wish I had a 30 or 50 ton instead of the 20 ton.
Yup thought about that but I felt like fabricating!
Got to use it tonight to straighten a 3/16 plate approx 12x14" that fits my rear blade for snow removal.
It hit an immovable object last winter and had a good bend in it; worked like a charm but man does this thing EAT air!!
Will add pics of the repair later
   / Red Torin 20 ton shop press mod #20
I saw a neat modification to a press. A 1/4" cable down each side with a small winch ( like they have on boat trailers ) to move the table up and down. Sure looked easier than manually lifting to pin it in place.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2017 PETERBILT 567 TRIAXLE (INOPERABLE) (A52472)
2017 PETERBILT 567...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
