Red Torin 20 ton shop press mod
   / Red Torin 20 ton shop press mod
What you've done so far looks good. I thought you were going to get a different jack though? Why go through making the base for this one if your getting a diff one? Or that thought has passed?
Lol Sorry I didn't post the original jack; probably should have. I will post the original manual jack with the new air/hydraulic jack. Will also post progress pics tonight Sorry for any confusion I may have caused
   / Red Torin 20 ton shop press mod #12
Didn't confuse me, I saw the new jack in the first pictures! :D
   / Red Torin 20 ton shop press mod #13
haha my bad.. I saw the "manual" handle receiver in one of the zoomed in pics.. Didn't realize there was more! And also I guess didn't realize that air over hydraulic still has manual use if air isn't there...
Well got the plate done and primed.
Gotta admit I should not have welded the inside edge (I knew this and did it anyway) as the jack did not sit on the plate as the weld caused interference.
Nothing a little grinding couldn't fix...
Will paint black tomorrow after the primer cures.
Will post pics of the completed product.
Here is the finished jack/u-channel plate.
My next step is to make some type of platform to raise the press up 8-12" and have it mobile on casters.
Wood or steel for this platform?
   / Red Torin 20 ton shop press mod #16
Either will work beautifully. Any material in stock? I always tend to lean that way... Someone made a good point earlier though, that the wood deck is a much better dampener if it comes to an "oopsy"...
Have some angle and 1-1/2" square tubing that I can use so I may use a combo of steel frame and plywood deck.
   / Red Torin 20 ton shop press mod #18
Nice work. On my home made press I just cut off a 3/8" ring of pipe the top of the screw fit into & tacked it in place. I slide the jack under it, a few twists & it is secured in place. I love may air over hydraulic jack! Just wish I had a 30 or 50 ton instead of the 20 ton.
Yup thought about that but I felt like fabricating!
Got to use it tonight to straighten a 3/16 plate approx 12x14" that fits my rear blade for snow removal.
It hit an immovable object last winter and had a good bend in it; worked like a charm but man does this thing EAT air!!
Will add pics of the repair later
   / Red Torin 20 ton shop press mod #20
I saw a neat modification to a press. A 1/4" cable down each side with a small winch ( like they have on boat trailers ) to move the table up and down. Sure looked easier than manually lifting to pin it in place.
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2012 John Deere 6170R (A57148)
2012 John Deere...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
