Recondition a spring?
/ Recondition a spring? #1
Boulter
Central Ontario
Kioti DK40SE
Hi:
This spring doesn't happen to be on a tractor, so I am off topic, but I figure folks here will know how to proceed. I beg your indulgance.
Somehow a 10 cent part leaving on a boat out of China is going to cost me $25 plus taxes for a new one. This is clearly unacceptable.
I have a torsion spring that pulls the guard over the cutter head on my jointer. It has yielded a bit at both ends. Could one heat it with a torch to take out the temper, bend it back into shape, and harden it again? If this is reasonably possible, specifically how would one proceed?
Or is it likely that a spring could be found off the shelf? I don't think springs exist as standardized items like screws, but maybe I am wrong.
I probably would have choked down $10, but $25 cripes.
I guess I could also convert the system to use a tension spring as is done on my Rockwell 4 inch jointer by drilling and tapping a few holes.
Thanks for any suggestions.
Boulter
/ Recondition a spring? #2
Hi:
Boulter
Springs can be found at many good hardware stores. Also the company, McMaster-Carr handles online sales.
/ Recondition a spring? #3
Unless its something really strange, universal type springs are available pretty much anywhere.
/ Recondition a spring? #4
Do U really mean torsion? or is it like mine, a coil with hooks at both ends that pulls the the guard over the cutter head.
Shucks, get a coil spring, drill a couple of holes and hook it up.
Or better still, drill and tap (say 10 x 32) fit a jam nut and tighten with , say 1/4" protrusion and hook the coil spring. Cheap and easy!
Good luck!
/ Recondition a spring? #7
The coil spring on my jointer broke. I just replaced it with a hardware replacement that fit.:D
/ Recondition a spring? #9
if you have a Northern tool close or order online you can buy a kit with assorted type springs in it for aroound 10 to $15
Good luck!
I believe torsion is the right word. It stores energy by twisting, not lengthening (tension spring) or shortening (compression spring).
What you describe is probably what I will do. In fact older models of my particular jointer were done this way, as is my smaller jointer.
Thanks to everyone for their suggestions.
Boulter
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
New/Unused IRMC Massage Chair (A61166)
New/Unused IRMC...
2021 John Deere 1023E Tractor Loader (A63116)
2021 John Deere...
New/Unused Pallet of 8 Binders and 16 Chains (A61166)
New/Unused Pallet...
CATERPILLAR GC25K STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR GC25K...
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61568)
2012 Toyota Tundra...
