Recondition a spring?
/ Recondition a spring? #1
Boulter
Member
Central Ontario
Kioti DK40SE
Hi:
This spring doesn't happen to be on a tractor, so I am off topic, but I figure folks here will know how to proceed. I beg your indulgance.
Somehow a 10 cent part leaving on a boat out of China is going to cost me $25 plus taxes for a new one. This is clearly unacceptable.
I have a torsion spring that pulls the guard over the cutter head on my jointer. It has yielded a bit at both ends. Could one heat it with a torch to take out the temper, bend it back into shape, and harden it again? If this is reasonably possible, specifically how would one proceed?
Or is it likely that a spring could be found off the shelf? I don't think springs exist as standardized items like screws, but maybe I am wrong.
I probably would have choked down $10, but $25 cripes.
I guess I could also convert the system to use a tension spring as is done on my Rockwell 4 inch jointer by drilling and tapping a few holes.
Thanks for any suggestions.
Boulter
/ Recondition a spring? #2
Hi:
Boulter
Springs can be found at many good hardware stores. Also the company, McMaster-Carr handles online sales.
/ Recondition a spring? #3
Unless its something really strange, universal type springs are available pretty much anywhere.
/ Recondition a spring? #4
Do U really mean torsion? or is it like mine, a coil with hooks at both ends that pulls the the guard over the cutter head.
Shucks, get a coil spring, drill a couple of holes and hook it up.
Or better still, drill and tap (say 10 x 32) fit a jam nut and tighten with , say 1/4" protrusion and hook the coil spring. Cheap and easy!
Good luck!
/ Recondition a spring? #7
The coil spring on my jointer broke. I just replaced it with a hardware replacement that fit.:D
/ Recondition a spring? #9
if you have a Northern tool close or order online you can buy a kit with assorted type springs in it for aroound 10 to $15
Good luck!
I believe torsion is the right word. It stores energy by twisting, not lengthening (tension spring) or shortening (compression spring).
What you describe is probably what I will do. In fact older models of my particular jointer were done this way, as is my smaller jointer.
Thanks to everyone for their suggestions.
Boulter
2005 International 4300 Hook Truck, VIN # 1HTMMAAM15H108569 (A61165)
2005 International...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
Topsoil Trommel (A57453)
Topsoil Trommel...
