gsganzer
Elite Member
- Joined
- Jun 11, 2003
- Messages
- 4,059
- Location
- Denton, TX
- Tractor
- L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
In the video, they said the foam heats up as it cures reaching 200 degrees F, so they just apply a thin coat first to minimize the heat and also to insulate the metal from the thicker final coat. I'm guessing that's what happened. Thermal expansion and then the foam hardens and results in the distortion. However, in another photo, it looked like it was the inside ceiling, also made from r-panels. So, possibly foam sprayed into an enclosed void.
Certainly, a question I'll be asking the foam contractors that bid the job.
Some others had mentioned a vapor/plastic barrier so panels can be removed or replaced later. I don't know how you do this and still have the foam properly adhering to the panels. The only reason I can see having to remove any panels is due to hail damage on a roof. I recently had hail damage at my house with a 70MPH hail storm, causing $72K in damage. An interesting thing to note is that the metal roof on my shop, that had roll insulation underneath and is more rigid suffered almost no damage. The adjoining shed roof that covers some horse stalls and is uninsulated underneath has dings all over it. I think if you sprayed foam to the back side of a roof, you'd also make it considerably more resistant to hail damage due to the added rigidity.
