WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 13,191
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
A lot of installers like to spray the foam right onto the underside of the roof. My big concern with this was that the foam would follow the exact ridge countour of the existing roof, and make future replacement very difficult, so I fit rigid foam insulation into east joist bay and had them spray against that.One other thing I'd research about a vapor barrier between steel roofing and closed cell foam is the possibility of trapping moisture between the vapor barrier and the steel roofing which could potentially destroy your roof... RUST.
This has two advantages, in that it doesn't block off any existing soffit-to-ridge ventillation which may help keep the underside of the roof dry, but also makes future replacement much easier. It was very easy to fit 2' wide sheets of the stuff between my rafters (24" on-center... or as close as 250 years of settling allows them to remain), and I just pressed the rigid foam insulation onto the purlins, and used a few drywall screws to lightly hold it in place.
