Recomended Hydraulic Hoses online?
   / Recomended Hydraulic Hoses online? #1
Telstar2112
Walton, NY
Kubota L35, GR2120
Last year I put a hydraulic thumb on my L35. I ordered the valve and hoses from Surplus center. Last week I was using the thumb a lot on some heavy rocks and noticed one of the hoses was leaking. Not at a wear point or fitting but just seeping out of the hose midway along its length. There was no sign of any damage. This is a 1/4" hose, 12' long with -6 female JIC fittings on it. Can someone recommend a good place to buy some higher quality hose online? Any particular type to look for? Also, on some sites some times the fittings are listed by the hose size, like 1/4" JIC, instead of -6. How do I know I am getting the -6 I need for my fittings? The hose is rated to over 5000 so not sure why it is leaking.
Steve.
   / Recomended Hydraulic Hoses online? #2
Isn't there a sponsor of this tractor forum who participates frequently on the hydraulics sub forum? Might check there.. (MTVIEW IIRC)
   / Recomended Hydraulic Hoses online? #4
I get mine from Discount Hydraulic Hose. They stock every kind of hose and fitting I've asked for or suggested a better alternate - all at good prices. The hoses seem to be good quality - no uv cracks or leaks (oldest is about 6 years I think).
   / Recomended Hydraulic Hoses online? #5
Here is the supplier that I recommend. Give them a call.
As far as your current seeping, stuff happens. Maybe the place you purchased from will stand behind it and give you a replacement, don't know without asking.
Oh, and you don't need 5000 PSI rated hose. 3000 is fine, it has an over 13,000 PSI bursting strength.
   / Recomended Hydraulic Hoses online? #6
Steve.
For hoses: Discount Hydraulic Hose. For fittings, valves, & cylinders: Surplus Center
Yeah, I was looking at discount hydraulic hose, they have one called Hydraulax Tough that looks good. But they listed the JIC female fittings by fraction, and I am not sure the 1/4" is equal to the -6 so I just posted them that question.
   / Recomended Hydraulic Hoses online? #8
I second the recommendation for discounthydraulichose.com -- you can pick exactly what kind of hose and fittings you want, and they custom make it and ship within 1-2 days. Prices are very good. Now that I know about them, I probably won't ever buy generic pre-fab hoses locally, as they always required adapters to make them work. It's a lot simpler and cleaner to get the proper fittings crimped right on.
   / Recomended Hydraulic Hoses online? #9
The -xx number is in 1/16ths of an inch for JIC fittings. So a -6 is 6/16 or 3/8". If you wanted 1/4" fittings those would be -4 (4/16=1/4)
   / Recomended Hydraulic Hoses online? #10
I just got two replacement hoses using Hydraulax Tough hose made up by them for the loader on our B2910.
The hose looks even better in person ;)
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51247)
(INOP) JOHN DEERE...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
UNUSED LANDHONOR LHR-PC90 HEAVY DUTY PLATE COMPACT (A51248)
UNUSED LANDHONOR...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2023 RHINO X1406 LOT NUMBER 60 (A53084)
2023 RHINO X1406...
