Recomended Hydraulic Hoses online?
/ Recomended Hydraulic Hoses online? #1
Telstar2112
Walton, NY
Kubota L35, GR2120
Last year I put a hydraulic thumb on my L35. I ordered the valve and hoses from Surplus center. Last week I was using the thumb a lot on some heavy rocks and noticed one of the hoses was leaking. Not at a wear point or fitting but just seeping out of the hose midway along its length. There was no sign of any damage. This is a 1/4" hose, 12' long with -6 female JIC fittings on it. Can someone recommend a good place to buy some higher quality hose online? Any particular type to look for? Also, on some sites some times the fittings are listed by the hose size, like 1/4" JIC, instead of -6. How do I know I am getting the -6 I need for my fittings? The hose is rated to over 5000 so not sure why it is leaking.
Steve.
/ Recomended Hydraulic Hoses online? #2
Isn't there a sponsor of this tractor forum who participates frequently on the hydraulics sub forum? Might check there.. (MTVIEW IIRC)
/ Recomended Hydraulic Hoses online? #3
I have had good luck with Surplus Center hoses;they were 1/4 of what our local NAPA wanted.
/ Recomended Hydraulic Hoses online? #4
I get mine from Discount Hydraulic Hose. They stock every kind of hose and fitting I've asked for or suggested a better alternate - all at good prices. The hoses seem to be good quality - no uv cracks or leaks (oldest is about 6 years I think).
/ Recomended Hydraulic Hoses online? #5
Here is the supplier that I recommend. Give them a call.
As far as your current seeping, stuff happens. Maybe the place you purchased from will stand behind it and give you a replacement, don't know without asking.
Oh, and you don't need 5000 PSI rated hose. 3000 is fine, it has an over 13,000 PSI bursting strength.
/ Recomended Hydraulic Hoses online? #6
Steve.
For hoses: Discount Hydraulic Hose. For fittings, valves, & cylinders: Surplus Center
Yeah, I was looking at discount hydraulic hose, they have one called Hydraulax Tough that looks good. But they listed the JIC female fittings by fraction, and I am not sure the 1/4" is equal to the -6 so I just posted them that question.
/ Recomended Hydraulic Hoses online? #8
I second the recommendation for discounthydraulichose.com -- you can pick exactly what kind of hose and fittings you want, and they custom make it and ship within 1-2 days. Prices are very good. Now that I know about them, I probably won't ever buy generic pre-fab hoses locally, as they always required adapters to make them work. It's a lot simpler and cleaner to get the proper fittings crimped right on.
/ Recomended Hydraulic Hoses online? #9
The -xx number is in 1/16ths of an inch for JIC fittings. So a -6 is 6/16 or 3/8". If you wanted 1/4" fittings those would be -4 (4/16=1/4)
/ Recomended Hydraulic Hoses online? #10
I just got two replacement hoses using Hydraulax Tough hose made up by them for the loader on our B2910.
The hose looks even better in person ;)
2014 Sea Ray 250SLX Bowrider Boat with T/A Boat Trailer (A59231)
2014 Sea Ray...
2020 DRAGON ESP...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
2018 Toyota C-HR Hatchback (A59231)
2018 Toyota C-HR...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
