Rechargeable Deer (Spot light)
/ Rechargeable Deer (Spot light) #1
iplumb
Mason MI.
B2920
In the market for a new Deer light. Anybody have one they really like? What brand where did you get it? Thanks
/ Rechargeable Deer (Spot light) #4
I just go with something small and cheap (under $30) with at least a one year wrty and keep the paperwork. Works just as good as a high dollar Surfire. Found usually at a big box store.
/ Rechargeable Deer (Spot light) #5
Qbeam is probably still the best. They have some at Walmart that are rechargable. I expect the sporting goods stores carry them, too. Cabelas, Bass Pro, etc. Check Sportsman's Guide, too, for a closeout special.
/ Rechargeable Deer (Spot light) #6
bought one at Dick's last week for $10 (1/2 off) rechargeable and yr warranty. tuff to beat.:)
/ Rechargeable Deer (Spot light) #7
Not from big lots or harbor freight. Heavyer is better (more battery).Pep boys?
/ Rechargeable Deer (Spot light) #9
I never had much luck with rechargeable lights. Charge for 4-6 hours for 20 minutes of use.
I had good luck with the brinks corded 2 million cp. have had mine for 20 years. I added about 8' of power cord though.
/ Rechargeable Deer (Spot light) #10
Horrible luck with Q-Beam, both batteries will not recharge after about 6 months of use.
Looking for another brand.
/ Rechargeable Deer (Spot light) #11
black and decker... can recharge from ac or 12v, has a good bright lamp, and can trigger lock it.. also has 2 suber bright white leds.. for low illumination when you don't need to read a book across the pasture with it..
soundguy
/ Rechargeable Deer (Spot light) #12
What model BD, or is there only one spotlight from them? I saw one in Lowes could that be it?
/ Rechargeable Deer (Spot light) #13
I just got a BD at Walmart for $25 and like it just fine. The charger is built in so no losing it, just needs a power cord. Way more light than the same priced Gander Mountain brand I got a month ago. The model number is SL102B. I also have a BD rechargeable LED worklight that I have put to a lot of use, construction site and home, for a year now.
/ Rechargeable Deer (Spot light) #14
I did get mine at lowes
model # VEC 157 BD
Have had it since last year.. great lamp.
save yer paperwork.. when/if the lamp element has to be replaced.. you have to order from them to get the correct wattage. it's like a 100w bulb.. but in the after market you can only find 50w and 75w replacements, except thru bd.. etc...
soundguy
Heavy Duty Plate Compactor (A64047)
Heavy Duty Plate...
2017 JOHN DEERE 333G TRACK SKID STEER (A63569)
2017 JOHN DEERE...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2007 STERLING LT9500 (INOPERABLE) (A63569)
2007 STERLING...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
