Rechargeable Deer (Spot light)
/ Rechargeable Deer (Spot light) #1
iplumb
Mason MI.
B2920
In the market for a new Deer light. Anybody have one they really like? What brand where did you get it? Thanks
/ Rechargeable Deer (Spot light) #4
I just go with something small and cheap (under $30) with at least a one year wrty and keep the paperwork. Works just as good as a high dollar Surfire. Found usually at a big box store.
/ Rechargeable Deer (Spot light) #5
Qbeam is probably still the best. They have some at Walmart that are rechargable. I expect the sporting goods stores carry them, too. Cabelas, Bass Pro, etc. Check Sportsman's Guide, too, for a closeout special.
/ Rechargeable Deer (Spot light) #6
bought one at Dick's last week for $10 (1/2 off) rechargeable and yr warranty. tuff to beat.:)
/ Rechargeable Deer (Spot light) #7
Not from big lots or harbor freight. Heavyer is better (more battery).Pep boys?
/ Rechargeable Deer (Spot light) #9
I never had much luck with rechargeable lights. Charge for 4-6 hours for 20 minutes of use.
I had good luck with the brinks corded 2 million cp. have had mine for 20 years. I added about 8' of power cord though.
/ Rechargeable Deer (Spot light) #10
Horrible luck with Q-Beam, both batteries will not recharge after about 6 months of use.
Looking for another brand.
/ Rechargeable Deer (Spot light) #11
black and decker... can recharge from ac or 12v, has a good bright lamp, and can trigger lock it.. also has 2 suber bright white leds.. for low illumination when you don't need to read a book across the pasture with it..
soundguy
/ Rechargeable Deer (Spot light) #12
What model BD, or is there only one spotlight from them? I saw one in Lowes could that be it?
/ Rechargeable Deer (Spot light) #13
I just got a BD at Walmart for $25 and like it just fine. The charger is built in so no losing it, just needs a power cord. Way more light than the same priced Gander Mountain brand I got a month ago. The model number is SL102B. I also have a BD rechargeable LED worklight that I have put to a lot of use, construction site and home, for a year now.
/ Rechargeable Deer (Spot light) #14
I did get mine at lowes
model # VEC 157 BD
Have had it since last year.. great lamp.
save yer paperwork.. when/if the lamp element has to be replaced.. you have to order from them to get the correct wattage. it's like a 100w bulb.. but in the after market you can only find 50w and 75w replacements, except thru bd.. etc...
soundguy
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2017 FORD F-250(INOPERABLE) (A63569)
2017 FORD...
