I just go with something small and cheap (under $30) with at least a one year wrty and keep the paperwork. Works just as good as a high dollar Surfire. Found usually at a big box store.
Qbeam is probably still the best. They have some at Walmart that are rechargable. I expect the sporting goods stores carry them, too. Cabelas, Bass Pro, etc. Check Sportsman's Guide, too, for a closeout special.
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
black and decker... can recharge from ac or 12v, has a good bright lamp, and can trigger lock it.. also has 2 suber bright white leds.. for low illumination when you don't need to read a book across the pasture with it..
I just got a BD at Walmart for $25 and like it just fine. The charger is built in so no losing it, just needs a power cord. Way more light than the same priced Gander Mountain brand I got a month ago. The model number is SL102B. I also have a BD rechargeable LED worklight that I have put to a lot of use, construction site and home, for a year now.
I did get mine at lowes
model # VEC 157 BD
Have had it since last year.. great lamp.
save yer paperwork.. when/if the lamp element has to be replaced.. you have to order from them to get the correct wattage. it's like a 100w bulb.. but in the after market you can only find 50w and 75w replacements, except thru bd.. etc...
