rebuilding offset disc
/ rebuilding offset disc #1
troweller
Kubota 3010, Farmall Cub
slowly rebuiding an old offset disc.
I ordered new discs and the hole where the 1 1/8 " square axle/gang bolt goes through the disc is 1/8" too big. The guy at the shop said that is the way it is supposed to be sloppy, but the old one's fit snug. I need some more clarification that the discs are supposed to be tight.
/ rebuilding offset disc #2
I'm only familiar with blades that fit tight on the shaft. Some come punched with a star pattern of 8 points - 2 different sizes. Loose blades would not line up quite right.
You could look at Shoup (probably the likely web address...) to compare different disk parts.
--->Paul
/ rebuilding offset disc #3
--->Paul
I think it's Shoup Manufacturing Company
/ rebuilding offset disc #4
There are two sizes for axels 1" and 1 1/8", sounds like you got the wrong size. I replaced an axel this summer on a Hardee and there was no "slop" on mine.
/ rebuilding offset disc #5
you can also try agrisupply.com I get my disc parts from them at very good prices
16ft. Aluminum Extension Ladder (A65640)
16ft. Aluminum...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
3'x8' Stack of Sheet Metal (A64127)
3'x8' Stack of...
2003 Isuzu NPR Box Truck, VIN # 4KLB4B1R13J801508 (A65563)
2003 Isuzu NPR Box...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
