rebuilding offset disc
/ rebuilding offset disc #1
troweller
Kubota 3010, Farmall Cub
slowly rebuiding an old offset disc.
I ordered new discs and the hole where the 1 1/8 " square axle/gang bolt goes through the disc is 1/8" too big. The guy at the shop said that is the way it is supposed to be sloppy, but the old one's fit snug. I need some more clarification that the discs are supposed to be tight.
/ rebuilding offset disc #2
I'm only familiar with blades that fit tight on the shaft. Some come punched with a star pattern of 8 points - 2 different sizes. Loose blades would not line up quite right.
You could look at Shoup (probably the likely web address...) to compare different disk parts.
--->Paul
/ rebuilding offset disc #3
--->Paul
I think it's Shoup Manufacturing Company
/ rebuilding offset disc #4
There are two sizes for axels 1" and 1 1/8", sounds like you got the wrong size. I replaced an axel this summer on a Hardee and there was no "slop" on mine.
/ rebuilding offset disc #5
you can also try agrisupply.com I get my disc parts from them at very good prices
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
1901 T/A CAR HAULER TRAILER (A59914)
1901 T/A CAR...
Dodge 5500 Bucket Truck (A63689)
Dodge 5500 Bucket...
2014 FORD F-150 (A65643)
2014 FORD F-150...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
