rebuilding 1610D engine.
/ rebuilding 1610D engine. #1
jmf7112001
Eastern Ala
Many different models
I'm starting to restore one it has a cracked cylinder wall. Does this engine have replacable inserts?
/ rebuilding 1610D engine. #3
No replaceable liners on that one. It depends on where the crack is a good machine shop can do wonders and sleeves are commonly installed in cracked blocks the crack needs to be magnafluxed at the minimum. Keep one thing in mind there could be cracks elsewhere and probably are. Why did it crack anyway do you know the history? Did it freeze up or overheated and someone added water?
If the crack extends below where the boring would stop at the bottom of the cyl to index the bottom of the sleeve it wont work also if it extends to the deck it may create head gasket issues depending on the area it extends to and whether the gasket seals it or not. Personally I wouldn't sleeve it if it went to the deck but if its the last block on the planet which Coldwater in the next post proves its not :thumbsup: thats the only way I would take a chance.
thank you, but i would like something closer to alabama, so i can see it before i buy it. Anybody got a 1610D short block at a reasonable price in southern USA
/ rebuilding 1610D engine. #6
You can't buy short blocks,or rebuilt engines-they don't exist. All you can do is search the junk yards.
/ rebuilding 1610D engine. #8
just for the fun of it what do you all think a good running used ym1610/1601 short block should cost?????
/ rebuilding 1610D engine. #9
x2 on trying West Kentucky Tractor parts. I have dealt with them and they have great service.
/ rebuilding 1610D engine. #10
Uh, yours lemme guess.....hmmm? For a short block, i would say $1000? You dont have to answer me here if you dont want to im just playing a guessing game!
/ rebuilding 1610D engine. #11
Well jmho and its yet to be seen but if the OP engine needs a block it needs a head also. but thats just my years of working on damaged engines talking.
/ rebuilding 1610D engine. #12
good guess it i sold it on saturday for $800 for a short. a good one is a ym155 same as ym1300 that one will go for hole engine $1500
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
2013 Ford Taurus AWD Sedan (A64194)
2013 Ford Taurus...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2000 Chevrolet Astro Passenger Van (A64194)
2000 Chevrolet...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
