Rear Work Light
/ Rear Work Light #1
MikeyB
Parker,CO
JD 3320
I have a relatively new 3320 and would like to have a rear work light. I have seen quite a few threads with owners adding their own light and wiring but I am curious if the wiring harness is already installed? I notice quite a few capped harness plugs on the rear of the tractor. Are any of these wiring for a light that I could install? Of course, a switch to operate the light without turning on the rest of them is a different story. Thanks for any info.
Regards,
Mike
/ Rear Work Light #2
I can't speak for the 3320 but I added a light to my 790 and the harness was there. It was under the seat and it is controlled by my main light switch. Check your manual, the shop manual or wait for someone with a 3320 to chime in. Good chance it is all there for you.
/ Rear Work Light #3
I would say the wires are already there. If you go to deere.com and look in the parts for the 3320 it shows ther rear work light. With it is a short wire harness. Finding the correct harness will be the trick. There will be several different harnesses back there. One will be for a back-up alarm.
/ Rear Work Light #4
I have the cab mounted 3320, I don't know about the non-cab. Mine was pre-wired and just needed to be mounted, plus it uses another rocker switch connected thru the harness to turn it off and on when the lights are on. The why to that question I still don't understand. Deere hooked mine up for around $100 including the lights.
/ Rear Work Light #5
I hooked mine up on a 4410 (the predecessor to the 3320). The wiring was all there for me, and was color coded. About a 10 minute install. It is, however switched with the headlights. I haven't found that to be a problem.
/ Rear Work Light #6
The JD rear work light is $39 and you can install it in about 5 minutes. It comes with the wiring harness already attached. The housing is rubber coated, the light is very bright and it has a tension adjustment where you can reach back and grab it and tilt it as needed. It stays where you leave it tilted. They come on with the headlights. I bought two, one for each fender. I could have rigged up some generic lights and done some wire splicing and probably saved $15 per light. To me, time is money and these were professional lights that installed in 5 minutes using only a socket set and one wrench.
My son-in-law worked one night from about 11PM until 3AM running the backhoe. The lighting was great. He had just got off work and was still full of energy. When I got up the next morning, a half day of work was done.
/ Rear Work Light
Thanks for the reply guys. My dealer had one in stock so I will be installing it this weekend. Next question is, where did you install yours? Some put it on the fender(s), anywhere else you would suggest? Dealer says on the (in)side of the rops, level with the turn signal flashers.
Regards,
Mike
/ Rear Work Light #8
Each of my fenders had a hole for the light already so I had my pick. I chose the left fender as I normally look over my right shoulder when looking to the rear. Nice sidelighting effect to my work!
/ Rear Work Light #9
Look for a hole in each fender behind the turn signal. If it is there, installation will take 5 mintes. There should be no need to drill the ROPS.
I will bet you will go buy the second one after you see the first one installed.
/ Rear Work Light #10
MikeyB said:
... Dealer says on the (in)side of the rops, level with the turn signal flashers.
That's where the instructions will say to put it and where the wiring harness will be easily accessible. Same bolts that hold the turn signal on will hold the rear work light.
/ Rear Work Light
Thanks for all the replies. Installed it this weekend. Just like you all said, about a ten minute job. Hardest part was fishing the wires down the rops. Had to use the old metal coathanger trick to fish the harness down the rops. Most guys seem to have two lights, is that possible or do you have to do some customization as far as splicing the second light into the same harness? Although, if I got the second light I'd have to move my fire extinguisher which is mounted on the right side of the rops using the turn signal bolts.
Mike
/ Rear Work Light #12
Look on the other side for the second harness. JD makes it easy to sell you a second light.
/ Rear Work Light #13
Yes, you can get two light kits installed. I have both on mine and there are wiring harnesses on both sides to tap. I also put the running lights on either side also and they work well too. Fishing all of those wires was a trick (I used a fish), but it is nice to have the extra lights when working.
-Bob
/ Rear Work Light #14
Gordon21, could you give me the Kit or Part No. for that work light. I tried looking in up in JD parts and the bulb alone was the price you quoted. I'm guessing I'm not looking at these parts correctly.
/ Rear Work Light #15
Try BM17981 BM numbers are kits or complete assemblies of multiple parts. I haven't been able to find pricing for complete kits on line. I paid about $39
I don't think you will need part AM108244 which is a harness extension. One male and one female plug and an extra 8" of wire. It does not come in the kit.
/ Rear Work Light
The part no. for my 3320 was LVB25547 Rear Work Light. That is for the light, attached bracket, and wiring harness. Hope this helps.
Mike
This is the part no. on the JD parts online catalog. It was about $40 and my JD dealer brought it out to my house. Now that's service!
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
BUSH HOG RD-600 ROLLOVER BOX BLADE (A64280)
BUSH HOG RD-600...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61574)
2014 Crossroads RV...
ASSET DESCRIPTIONS & CONDITION (A59911)
ASSET DESCRIPTIONS...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
