REAR WHEEL SPACER ON 2720
   / REAR WHEEL SPACER ON 2720 #1
THOMASLEONARD
RUSH CITY MINNESOTA
JOHN DEERE 2720
Anyone know where you can get rear wheel spacers for John deere 2720 , so when have tire chains on the chains do not rub three point arms ?
   / REAR WHEEL SPACER ON 2720 #2
Do you have your rear tires mounted in the wide position? I have a 2720 with R4 tires in the wide position and even with heavy duty rear chains I have plenty of clearance on the 3PH arms. I also have chains on the front and I installed the front spacers that JD makes.
If your rear wheels are in the narrow position it will be a very tight fit for chains.
No I have them in the wide posistion. I also have independant lift for mover deck and the chains are way to close to the cable that sets lift height.
   / REAR WHEEL SPACER ON 2720 #4
Ahh... yes, I have seen those. Unfortunately they designed those with basically no room to spare.
   / REAR WHEEL SPACER ON 2720 #6
I know what you mean, I have the same set-up. The lift arms under the tractor for the MMM look like they will come off easy enough but I left them on my rig. They sway back and forth a bit so I figured they would be okay if the chain hit it occasionally. We have had only one snow so I may be changing my mind by spring but for now their hasn't been a problem.
3ft Teakwood Totem Pole (A57454)
3ft Teakwood Totem...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
Informational Lot - Shipping (A56436)
Informational Lot...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
TANK MANIFOLD (A55745)
