Interesting Wheel Spacer Experience
/ Interesting Wheel Spacer Experience
I actually took a reamer and cleaned out the holes for the studs and they were still visibly off. The hub was about 1/8" too big which is more than could be accounted for by paint. I did look at that though. I must have gotten a screwed up set.
/ Interesting Wheel Spacer Experience #12
I would just have the dealer order another set, and take that set by and have them try to mount them on another tractor just for kicks. Might not be machined incorrectly, could be for another tractor; even another manufacturer.
/ Interesting Wheel Spacer Experience #13
Does anyone know if the Kubota spacer kit is compatible with the mid mount mower on the new B series tractors (B2620) ? I'd like to get it for additional stability when mowing - already have loaded tires, but have a lot of steep hills.
/ Interesting Wheel Spacer Experience #14
I think the spacers move the wheels out about 1 1/2" on each side. Usually the problem is the rear anti scalp wheels on your mower deck. If there is more than that much clearance on your present setup, you should be all set.
/ Interesting Wheel Spacer Experience #15
it says right on the spacer kit that it is not compatable with mmm.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
