REAR WHEEL SPACER ON 2720
   / REAR WHEEL SPACER ON 2720 #1
THOMASLEONARD
RUSH CITY MINNESOTA
JOHN DEERE 2720
Anyone know where you can get rear wheel spacers for John deere 2720 , so when have tire chains on the chains do not rub three point arms ?
   / REAR WHEEL SPACER ON 2720 #2
Do you have your rear tires mounted in the wide position? I have a 2720 with R4 tires in the wide position and even with heavy duty rear chains I have plenty of clearance on the 3PH arms. I also have chains on the front and I installed the front spacers that JD makes.
If your rear wheels are in the narrow position it will be a very tight fit for chains.
No I have them in the wide posistion. I also have independant lift for mover deck and the chains are way to close to the cable that sets lift height.
   / REAR WHEEL SPACER ON 2720 #4
Ahh... yes, I have seen those. Unfortunately they designed those with basically no room to spare.
   / REAR WHEEL SPACER ON 2720 #6
I know what you mean, I have the same set-up. The lift arms under the tractor for the MMM look like they will come off easy enough but I left them on my rig. They sway back and forth a bit so I figured they would be okay if the chain hit it occasionally. We have had only one snow so I may be changing my mind by spring but for now their hasn't been a problem.
Deere 9970 Cotton Picker (A52748)
Deere 9970 Cotton...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
