Tire Selection rear tractor tires
/ rear tractor tires #1
rayway52131
Mariposa, ca
mf old maybe1960
Will a 11.2x24 tire fit on a wheel where a 14.9 x24 tire is? 11.2 seems to be readily available.
/ rear tractor tires #2
naa, you could go up to a max of a 13,6-24 or 2 levels.
11,2 12,4 13.6 etc,
it may look funny at 2 sizes up but usually fine
i think you will want a 12" wide rim for a 14.9 tire not 10" etc..
/ rear tractor tires #3
i think you read that wrong soundguy? He wants to put a smaller tire where a bigger tire is not the other way around. Or i read what you wrote wrong?
/ rear tractor tires #5
i said you can go two levels. a 14.9 uses a 12" rim. a 124. might fit on it.. but not an 11.2.
yeah i did read his post wrong for which way he is going.. however the info i posted is still applicable. only about 2 sizes difference works.
/ rear tractor tires #6
I would start by finding out what size rims you do have, and what model is the tractor.
Not enough information and too many assumptions for a 1960's tractor.
It is possible that it had 12.4's on it to begin with. Then at sometime years ago, someone put 14.9's on it. In that case yes, an 11.2 would likely work.
Rims are designed to work with a range of tires. Maybe 2 or 3 sizes. If the 14.9's are the MAX for that rim, then it might work to go smaller. IF the 14.9's are the minimum for that rim....not likely.
/ rear tractor tires #7
considering there are 16.9's available...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
Lot of (3) Heavy-Duty Pipe Gates (A66408)
Lot of (3)...
