Rear Tire Width
/ Rear Tire Width #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
My property is real hilly and rocky, I'll be getting a new dk40 next week (Hopefully)
I'll have 14.9x24 filled rear industrial tires. Should I have the dealer mount them in the widest position?
/ Rear Tire Width #2
If you have no reason not to (like narrow gates etc.) I would definitely have them mount them to the widest position.
/ Rear Tire Width #3
Unless there's a reason not to, set them all the way out.
/ Rear Tire Width #4
I may be wrong but I don't believe the rims for Industrial tires can be changed for width as you can do with the rims for Ag tires. I though the Industrial tire rims are one piece versus the two piece rims for Ag tires which are adjustable depending on how you mount the center on the rim.
/ Rear Tire Width
Good point Victor, maybe someone with a dk40se and industrial tires can chime in.
/ Rear Tire Width #6
On my 3016, my industrials are mounted on one piece wheels.
/ Rear Tire Width #7
On the DK 40/45/50 the rears are adjustable with R4 or R1s..outer rim bolts to inner disk.
/ Rear Tire Width
thanks grm61
/ Rear Tire Width #9
thanks grm61
Your welcome, mine came set wide, which is still not all that wide, I can angle my 7ft rear blade and still cover my tracks..
So yea, wide is the way to go.
/ Rear Tire Width #10
I swapped mine last winter. I'd never go back. However a 5 ft rotary cutter will not cover your tracks. I'm thinking of going to a flail. A 6 ft medium duty on a dk40 is underpowered
/ Rear Tire Width #11
Yes, at the widest setting, for sure. Unless there is some overriding reason that they must be narrower. Wide = stability.
/ Rear Tire Width #12
It really makes a difference when mowing ditches. The widest position is 75" outside measurement with the 14.9x24 R4s.
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
Westfield Conveyor (A61307)
Westfield Conveyor...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
John Deere 6120M (A57148)
John Deere 6120M...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2018 CHEVROLET EXPRESS 3500 4X2 BOX TRUCK (A59906)
2018 CHEVROLET...
