Rear Tire Width
/ Rear Tire Width #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
My property is real hilly and rocky, I'll be getting a new dk40 next week (Hopefully)
I'll have 14.9x24 filled rear industrial tires. Should I have the dealer mount them in the widest position?
/ Rear Tire Width #2
If you have no reason not to (like narrow gates etc.) I would definitely have them mount them to the widest position.
/ Rear Tire Width #3
Unless there's a reason not to, set them all the way out.
/ Rear Tire Width #4
I may be wrong but I don't believe the rims for Industrial tires can be changed for width as you can do with the rims for Ag tires. I though the Industrial tire rims are one piece versus the two piece rims for Ag tires which are adjustable depending on how you mount the center on the rim.
/ Rear Tire Width
Good point Victor, maybe someone with a dk40se and industrial tires can chime in.
/ Rear Tire Width #6
On my 3016, my industrials are mounted on one piece wheels.
/ Rear Tire Width #7
On the DK 40/45/50 the rears are adjustable with R4 or R1s..outer rim bolts to inner disk.
/ Rear Tire Width
thanks grm61
/ Rear Tire Width #9
thanks grm61
Your welcome, mine came set wide, which is still not all that wide, I can angle my 7ft rear blade and still cover my tracks..
So yea, wide is the way to go.
/ Rear Tire Width #10
I swapped mine last winter. I'd never go back. However a 5 ft rotary cutter will not cover your tracks. I'm thinking of going to a flail. A 6 ft medium duty on a dk40 is underpowered
/ Rear Tire Width #11
Yes, at the widest setting, for sure. Unless there is some overriding reason that they must be narrower. Wide = stability.
/ Rear Tire Width #12
It really makes a difference when mowing ditches. The widest position is 75" outside measurement with the 14.9x24 R4s.
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
(26) Mineral Tubs (A66408)
(26) Mineral Tubs...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
60 Traffic Cones (A65579)
60 Traffic Cones...
