Rear tire width?
/ Rear tire width? #21
<font color=blue>Kubota offers that thin tractor </font color=blue>
The B7500DTN is probably what you're referring to. I think it's marketed to vineyards, who I assume need a narrow tractor to fit between the rows.
My tractor did not come at the narrowest setting, but right in the middle. Not sure why they come with the wheels set as they are except for the fact that they have to be set somewhere.
/ Rear tire width? #22
I think the B7500DTN has the axles "chopped off", and maybe special wheels so that they can be set as narrow as possible. Don't really know, as I've only had a few pictures to look at.
My B7500 too came set at the middle setting. If I went wider, the wheels would be wider than the boxblade, which would be a bad thing. I certainly wouldn't go narrower.
/ Rear tire width? #23
My speed pedal "shock absorber" is under the foot pan, on the right side, next to the frame rail. While under the floor pan, lying on your back, pull on the speed pedal downward. You should see the linages move a 5 inch cylindrical device that has a corrigated rubber boot.
I don't think mine does anything worth while anymore./w3tcompact/icons/sad.gif
Peter S.
2008 Peterbilt 379 Semitruck (A64047)
2008 Peterbilt 379...
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
MOBLE 50 SAND CONVEYOR (A63569)
MOBLE 50 SAND...
2022 EZ-GO ELITE...
