REAR REMOTES
/ REAR REMOTES #1
JDAOWNER
WATERLOO NEW YORK
JD A--KIOTI DS4110
I WANT TO ADD 2 REAR REMOTES TO MY 4110. I'VE DONE SOME HYD. WORK, BUT NOT MUCH. WOULD IT BE CHEAPER TO BUY THE PARTS FROM AFTER MARKET, OR GET A KIT FROM THE DEALER. DELER WANTS ABOUT 500 FOR THE KIT. THAT SOUNDS LIKE A LOT, BUT I HAVEN'T DONE HIS WORK IN A FEW YEARS. 2 VALVES HOSES AND ENDS. THANKS FOR ANY HELP. ANYONE DONE THEIR OWN?
/ REAR REMOTES #2
If the $500 is for the factory Kioti set, then get it as fast as you can and be very very happy. :thumbsup:
/ REAR REMOTES #4
That's a very good - darn good - price for a remote kit that looks good and was made to fit the tractor. Almost too good compared with what most tractor brands want for rear remotes.... although you still have to add the hoses that go out to the implements. Buy them online.
If you are a hydraulics guy with metal-working tools & don't mind the mounting work, then you already know that you can buy valves online and cobble something together for somwhere about half that price. $250/300 would just be enough to buy you a medium quality 2 spool directional valve rated at 10/12gpm, a handle kit, a basic rt. angle valve bracket, a couple of 3' hoses with SAE ends, and some fittings.
all at Surplus Center & you can price it there.
But keeping it from looking homemade is going to cost more time than the difference in price.
luck,
rScotty
I buy when I can and make do when I must
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
UNUSED WOLVERINE QUICK COUPLER 2 (A64281)
UNUSED WOLVERINE...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2019 Nissan Sentra (A61574)
2019 Nissan Sentra...
