Rear Remotes on B2910
/ Rear Remotes on B2910 #1
cmhyland
Platinum Member
Woodstock Valley, CT
2000 Kubota B2910
I'm interested in possibly running a 3pt log splitter off my B2910.
I'd need rear remotes to do this.. Does anyone have an idea of the cost
of adding these and will the splitter cycle reasonable fast
with the pump volume on the 2910?
Thanks for any help.
Regards,
Chris
Dealer quoted:
Valve kit $378
Hose kit $165
Block $70
Plus labor if I have them do it...
Makes a stand alone splitter look like a better deal?
Regards,
Chris
/ Rear Remotes on B2910 #3
It's cheaper to roll your own using a Prince SV valve.
Valve cost is around $225 for 3 spools, another $45 or so for the valve hoses (you need 3 hoses), another $75 or so for QC's and fittings, and $70 for the rear aux hydraulic block.
I did this for my B2710 which is the same as your B2910. If you do a search you will find the writeup with pictures.
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
2014 TROXELL  140BBL VACUUM TRAILER (A65643)
2014 TROXELL...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
2011 BRENNER TANK 200BBL CRUDE TANKER (A65643)
2011 BRENNER TANK...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
New/Unused Pallet of Chains, Binders, and Chain Slings (A65583)
New/Unused Pallet...
