Rear Remotes + 3rd Function Option
/ Rear Remotes + 3rd Function Option #21
@winterdeere……..I don’t think mine does that, but I will check. My third function is electric diverter/switch. Thanks!
Depends on whether solenoid power comes from "battery hot" or "key hot" source. The OEM connection for Deere solenoids is from key hot, at least on 3-series and similar.
/ Rear Remotes + 3rd Function Option #22
... and to add to what LouNY was saying, this might mean turning your key back to Run position after shutting down, to actuate any solenoid valves. I have to do this with my rear and loader 3rd function valves.
Yes.... I agree with WinterDeere; I wired my electric diverter valve direct hot (fused) from the battery and I need to turn my key to the on position (engine off) and operate the curl several times to relieve any pressure that remains in the line.
/ Rear Remotes + 3rd Function Option #23
Third function is key hot……
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2017 FORD F-150XL CREW CAB TRUCK (A59823)
2017 FORD F-150XL...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
