Rear Remote question
/ Rear Remote question #1
beltfed
Northern VA
Bobcat CT235
My CT235 didn't come with rear remotes, but lately I kind of wish I had at least one for controlling the side to side pitch of my rear blade. (Getting tired of cranking) Since I only have a rear blade I don't see a need for the toplink but if I were to get 1 remote, I'd probably get both now just incase.
My question. Can the parts be installed myself and are they everything I'd need? The cables, instructions, lever to control etc. My dealer is 25 miles away and I don't have a trailer so I'd rather not pay for a pickup for service if I can do it myself.
Lastly, where do I go about looking for the side hydraulic part? I don't know what size in length or anything about what I need. Does anyone have any suggestions? My rear blade is a 6' Leinbach SO6 blade if it matters. About 400 pounds.
Thanks.
/ Rear Remote question #3
Installing the rear remotes is pretty straight forward. They come with instructions and a set of wrenches and sockets should do. Everything you need is there in the kit. You don't have to be a mechanic to do this. It took me under 4 hours to install and check a dual set. I could do it faster now. The seat needs removed to get room to work.
You can check this site for the hyd link: Tractor Hydraulic toplinks, Top-N-Tilt, Side link cylinders If you call them, they will either know which one you need or will explain how to measure so you get the proper size. There are other places to buy these like some of the links/advertisements on TBN. Don't forget to buy the hoses to go from the hyd side link cylinder to the rear remote and you'll need two quick disconnects for the ends of the hoses to match up to the remote outlets.
/ Rear Remote question #4
Remove the seat. Install yourself. I did mine. Not hard, follow the instructions.
/ Rear Remote question #5
Thanks.
2" cylinder, 4" stroke with 16" or 17" center line at hole to hole mid stroke. Remember that you need a clevis at the top, not a ball joint.
/ Rear Remote question #7
I would definately install both remotes at one time! As for the cylinders, I have a top link by CCM... and my side link was built for me by Brian "MtnViewRanch" (two posts above). Both are very high quality with nice craftsmanship.
/ Rear Remote question #8
$792.00 to get the 1 into 2 rear remotes from the factory, can it be done for less thru parts?
I called up my Bobcat dealer and they quoted me in the low 400's for both remotes. I said go ahead and order and I'll pick them up in a week or so. It should have all the parts and hoses I need.
Next is the side link. I'll ask if Bobcat has something already setup for what I need but I'm not hopeful. I'll checkout some of the links you guys posted and then I guess all I would need is the hoses.
I won't get a toplink yet as all I have is a rear blade so I don't see a need for that, yet.
/ Rear Remote question #10
I bought two pair of rear hydr. remotes for my CT450 and installed with the help of my neighbor
/ Rear Remote question #11
The kit cost around $600.
/ Rear Remote question #12
Sprocket, did you get the side link installed? If so, how much would you say the tilt cylinder has helped in your grading?
Just wondering, I think that some people tend to use them more than others that have them and your conditions-projects are very much in favor of using it, a lot. :D
I can't seem to find many hydraulic cylinders (searching the web) which fit my specs. 2" cylinder with 4" stroke. Somewhere around 14-18" from retracted to extended (hole to hole) It is also clevis on both sides which I'll need. Several are close to the specs but more are much longer and cost around 200 dollars.
I decided to try ebay and ran across this: 2" Bore, 4" Stroke, Tie Rod Hydraulic Cylinder - eBay (item 280429907209 end time Oct-22-10 19:47:56 PDT)
buy it now for 51.80 - you can't beat the price, I'm just wondering if it will work properly. You probably get what you pay for but for that price I might just give it a try.
/ Rear Remote question #14
Keep in mind that it will be very difficult at best to find a standard hydraulic that is going to work out properly for a side link cylinder. Most if not all are going to need some sort of alteration.
There is a reason that they cost $250.;)
/ Rear Remote question #15
Brian, Yes the side link you built for me is installed and working great. I have not yet given it a real workout, but my barn will be removed this weekend and I will start grading for the larger barn on Saturday. I installed it on the right side and moved the manually adjustable link to the left side in place of the solid link as you suggested to give maximum adjustability.
Mark
1999 John Deere 7810 (A60462)
1999 John Deere...
ATLAS TC-229 ELECTRIC/AIR TIRE CHANGER (A64281)
ATLAS TC-229...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Dexter trailer axles (A61567)
Dexter trailer...
2026 Kearney 7'x20' Trailer (A64119)
2026 Kearney...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
