Rear Remote Issue
/ Rear Remote Issue #1
NC HILLBILLY
Hayesville, N.C.
2005 John Deere 5205
Howdy,
This is my very first post with hopes that I can get some guidance with a rear remote issue. I have a 2005 John Deere 5205 with about 600 hours on the clock. I finished this year's bush hogging and put my 6' Woods Hydra assisted scrape blade on for fall and winter road work. After hooking the two hoses up from the blade, I found that the control lever was frozen and would not move from side to side. It was working fine when I last used in about 6 months ago. I tried removing and reattaching the hoses but that did not help. I'm not very mechanically inclined but are there any ideas whats going on and suggestions as to what I can do to free up this lever..........Thanks in advance for any help or ideas..........Mark
/ Rear Remote Issue #2
Howdy,
How are the other hydraulics working?
/ Rear Remote Issue #3
It's possible the detents under the cap(parts key #1) are stuck or the spool is stuck. Apply PBblaster.Kroil or your favorite penetrating oil
/ Rear Remote Issue
Thanks for the replies. I did squirt some WD-40 at the base of the joy stick without success. I can try again at that specific area. All the other hydra have been working fine. Thanks Again.......Mark
/ Rear Remote Issue #5
Okay, then it is something specific to that spool/cylinders. I wonder if the spool itself jammed. Unusual that would happen. Did the lever get bent or hit?
/ Rear Remote Issue
Thanks for the reply TomSeller. I went back over to the farm property today and really hit it good with the WD-40. I then very slightly tapped the base, where the rod attaches, with a hammer and it finally freed up and is working great. Again......a big thanks for all that have tried to help..........Take Care.........Mark
Okay, then it is something specific to that spool/cylinders. I wonder if the spool itself jammed. Unusual that would happen. Did the level get bent or hit?
/ Rear Remote Issue #7
Okay great. A spool can jam but since it is oil in the lines it is seldom that would happen. You may want to make sure your fluid isn't contaminated with water. If it is, it will look cloudy or milky in extreme cases? Check after it is running.
/ Rear Remote Issue
Will Do !!!!!!!!
Okay great. A spool can jam but since it is oil in the lines it is seldom that would happen. You may want to make sure your fluid isn't contaminated with water. If it is, it will look cloudy or milky is extreme cases? Check after it is running.
2023 JCB 3TS-8T TELESKID (A65053)
2023 JCB 3TS-8T...
FUEL TANK WITH PUMP AND HOSE (A68842)
FUEL TANK WITH...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
PORTA POTTY (A67714)
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
