rear pto hyd.pump
/ rear pto hyd.pump #1
seedman4
Can i use pto shaft mounted hyd.pump to operate a independent hyd. clyinder? I have the pump,oil tank and a logsplitter valve.
The reason for the quistion is that i have a mahindra 3525 that has no rear hyd.remotes.i want to add a FEL grapple...
i know i will have to buy extra hyd.hoses to run from the pump to the cylinder.....BUT CAN IT BE DONE????
/ rear pto hyd.pump #2
To make sure we understand correctly...You have a FEL, but want to add 1 additional circuit to operate a grapple?
Yes, you can do what you said, but I think a electric diverter or a true rear remote would be a whole lot easier than what your planning...but it can sure be done your way.
/ rear pto hyd.pump #3
I've been having a similar discussion on a different thread.
Using the electric diverter is definately easier but more expensive if you already have the pump.
The big question is the GPM of your PTO pump. You can share the hydrolics on your tractor to run the grapple and do fine but most tractor pumps are too low volume to run a hydrolic motor of any size.
It's not what you are talking about but I'm thinking about coverting my tractor to skid loader attachment. If you were running the third hydrolic from it's own pump you could run snowblowers, brush cutters, sweepers, or even a hydrolic driven bush hog off the FEL (great for pushing back the encroaching forest.
I don't want to spend the money for the pump, reservour, ect but if you already own it, it would give you alot of flexibility.
/ rear pto hyd.pump #4
Dangerdoc,
Have you made any progress in your thoughts regarding building a pto hydro system for skidsteer style attachments?
I was talking to a rep at Erskine today about that very thing, since I want to use their hydraulic front mount snow blower rather than the long shaft pto model. I suggested that they develop a turnkey product to provide skidsteer hydo capability to tractors.
I was thinking about setting up a system on a 3 point carry-all to include the 25 gallon resevoir, pump, hoses, etc.
The idea of opening up the utility of skid steer attachments for the tractor is enticing.
/ rear pto hyd.pump #5
RFB said:
Dangerdoc,
I have an unused port coming off the pump. I'll be limitted to about 12 gal/min but I'm anxious to get a 4n1 going and it will be the quickest and leat expensive path to get there.
I may still a still add a pump later if I end up needing greater flow.
/ rear pto hyd.pump #6
Yes, the OP is talking about a grapple for the FEL, which requires no more
flow that the FEL itself uses. When you say "most tractor pumps are too
low volume to run a hydrolic motor of any size", be careful. You can buy
hyd motors designed to run with flows of less than 10GPM, as used for
compact tractor implements like PHDs. It is true that many skid steers
offer higher flows, so implements designed for them may expect to have
over 10GPM available. Continuous duty hydraulic power delivery, as for
a mower, and intermittant duty (PHD) are important considerations, too.
/ rear pto hyd.pump #7
dfkrug,
Sir,
I am looking at the Prince pto hydro pump which specs out about 21 gpm for 32hp input. This would match up good with my 5030 which produce 42 pto hp.
Do you see anything problematic in the intended setup (3 point carry-all to include the 25 gallon resevoir, pump, hoses, etc.) to obtain skid steer implement capability (of course within the confines of a 20gpm hydro flow).
/ rear pto hyd.pump #8
You mean a Kubota L5030? It has an implement pump that delivers 9.8
GPM at somewhere betw 2000 and 2500psi. Not bad. A Bobcat 753
delivers 15.9GPM for comparison. Certainly more flow with the SS.
If that is not enough for the implements you contemplate using, then you
certainly could use that pump/res/filter system for more flow. Realize that
valve(s) you use with that pump will need to have their reliefs set (at about
2500) as the pumps usually do not have reliefs. Also, if you use the 3PH
to support your aux hyd system, what will you do to counter-weight your
heavy front implements?
/ rear pto hyd.pump #9
Sir,
The first implement planned is an Erskine hydro snowblower requiring 11 to 25 gpm, and Erskine said 10 would not do it. I am also contemplating a hydro post hole digger, etc.
My tires are loaded with Rimguard for about 1000lbs, and the pump setup and fluid will add about another 175-200 (Hydro oil about 7.19 per gallon)
Keep tearing the idea, I need to find the issues.
/ rear pto hyd.pump #10
RFB:
Sounds like you have been looking at the snowblower choices available.
It would be nice if there were choices that allowed the use of your
tractor's hyd system. I don't do snow myself.
Separate hyd systems ARE sometimes used when a CUT can't deliver the
needed flow. It was fairly common for backhoes on older tractors that
had a hard time putting out 5GPM when 7 or 8 was needed.
The only other thing I can think of is if you use AG tires. The fronts may be
overloaded with a heavy implement on the front and minimal counter-weight.
(Wheel weights and fluid don't help here since they do not take weight off
front tires.)
/ rear pto hyd.pump #11
"...if you use AG tires"
You must be a physic (courtesy of "Curly" Howard)
I do use R1's; they are mandatory for my terrain and usage. I have successfully done a few 3,000 lb sod pallets, and 2000 lb pallets of flooring. They were kinda squishy but handled the chore. Pushing the envelope, but not a steady diet.
It routinely handles my 7.5 foot Curtis snowplow very well (which due to it's attachment system has a long angle moment).
Generally, most of what I plan will be close to the ground or resting on it (snow blower, auger, brush hog, so I am not too concerned. Your point nonetheless is valid.
I need to think of how and where I will locate the valve for the flow to the implement, and still access it from the cab (HSTC 5030). I have no rear remotes, so those slots are open, but I am not even Mr.Goodwrench's 3rd cousin twice removed.
/ rear pto hyd.pump #12
RFB said:
Dangerdoc,
I've been thinking along the same lines as you RFB. Please post pix if you start building such a pump setup for a snow-blower, etc.
/ rear pto hyd.pump #13
Here is one I did a few years back to power a rotary cutter on the FEL
/ rear pto hyd.pump #14
OOPS. Here it is, I think.
/ rear pto hyd.pump #15
Farmerford,
Sir,
That is right in line with how I envision the project. Can you elaborate on the setup including any potential problem areas?
Added: I found your older post with photos and am perusing that. Will followup after I brain stew what I read.
thanks very much for the direction.
/ rear pto hyd.pump #16
Yeah, my first degree was in physics (Michigan State). Then EE. Science
has always been my "calling".
It looks like FARMERFORD has just the ticket.
As for the hyd valves, since you have the cab version of the L5030, it may
be a challenge locating an aftermarket 1-spooler or 2-spooler. The factory
slots are for the integrated remote levers that use the tractor hydraulics.
I highly recommend that you get at least one rear remote that uses the
tractor's hyd system so you can at least get a hyd toplink. This will make
all rear implement mounting much easier. As for the valve for your PTO
system, normally I would put such an aftermkt valve on the rt fender or
rt rear ROPS post. With the cab, you may have to look elsewhere.
If you build something like FARMERFORD's, you might also consider
incorporating some ballast into it. Maybe cast the base out of concrete?
As for AG tires, nothing has their traction and I miss that. My main tractor
now has R4s and traction is WAY less, but they support much more weight.
Good luck!
/ rear pto hyd.pump #17
I was out plowing snow all day. Started at 0900, finished at 1900.
Kind of funny; all day I was thinking of your ballast question and I thought: I can make a cast concrete ballast with a horizontal draw bar with integral pins, and a top link attachment point) as ballast for the rear of the tractor and to function as the pump system platform. My next thought is to also cast embedded bolts into it and then cover the top of the concrete with marine grade plywood as the work platform.
Then I checked this thread and you mentioned a cast concrete ballast.
I told you that your were a physic.
/ rear pto hyd.pump #20
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
