Rear hydro hook up
/ Rear hydro hook up #1
jimmachinist
Meadville Pa
Kuboya L3710
How hard would it be to run two lines to the rear of my L3710 so I can hook the backhoe up easier? Can I just use black pipe or do I need special line? Thanks for the imput.
/ Rear hydro hook up #2
Unless you use heavy wall black pipe it is not strong enough to with stand the pressure.
NOTE: Never use galvanized pipe for hydraulic lines.
Threaded connections pressure ratings.
schedule 40 pipe:
1/2" 663 PSI
3/4" 631 PSI
Schedule 80 pipe:
1/2" 1932 PSI
3/4" 1722 PSI
Schedule 160 pipe:
1/2" 3334 PSI
3/4" 3528 PSI
Flow rates at 10 feet per second:
schedule 160
1/2" 5.3 GPM
3/4" 9.2 GPM
Steel tubing
1/2" OD x .049 wall thickness rated to 2650 PSI
1/2" OD x .065 wall thickness rated to 3600 PSI
5/8" OD x .065 wall thickness rated to 2850 PSI
5/8" OD x .083 wall thickness rated to 3700 PSI
3/4" OD x .065 2350 PSI
3/4" OD x .083 3050 PSI
Flow rates at 10 Feet per Second
1/2" x .049 3.9 GPM
1/2" x .065 3.35 GPM
5/8" x .065 6 GPM
5/8" x .083 5.1 GPM
3/4" x .065 9.4 GPM
3/4" x .083 8.34 GPM
Depending on your skills and tool availability tubing cab be bent and flared or ORFS brazed on.
Thank you for the input. I do have bending tools and a flaring tool so I'll go that route. Wasn't sure how to go about it or what to use. You cleared it all up now. Better to ask a dumb question then spend a lot of money and aggravation doing something all wrong. I know how to machine but the tractor is all new to me and I don't want to screw anything up. Thanks again.
/ Rear hydro hook up #4
Jim,
only dumb question is the one you don't ask.
Roy
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Land Hero Mini Skid Loader (A66408)
Land Hero Mini...
JOHN DEERE 310G BACKHOE (A65053)
JOHN DEERE 310G...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
5' Dearborn Disc (A62613)
5' Dearborn Disc...
