Rear hydro hook up
/ Rear hydro hook up #1
jimmachinist
Member
Meadville Pa
Kuboya L3710
How hard would it be to run two lines to the rear of my L3710 so I can hook the backhoe up easier? Can I just use black pipe or do I need special line? Thanks for the imput.
/ Rear hydro hook up #2
Unless you use heavy wall black pipe it is not strong enough to with stand the pressure.
NOTE: Never use galvanized pipe for hydraulic lines.
Threaded connections pressure ratings.
schedule 40 pipe:
1/2" 663 PSI
3/4" 631 PSI
Schedule 80 pipe:
1/2" 1932 PSI
3/4" 1722 PSI
Schedule 160 pipe:
1/2" 3334 PSI
3/4" 3528 PSI
Flow rates at 10 feet per second:
schedule 160
1/2" 5.3 GPM
3/4" 9.2 GPM
Steel tubing
1/2" OD x .049 wall thickness rated to 2650 PSI
1/2" OD x .065 wall thickness rated to 3600 PSI
5/8" OD x .065 wall thickness rated to 2850 PSI
5/8" OD x .083 wall thickness rated to 3700 PSI
3/4" OD x .065 2350 PSI
3/4" OD x .083 3050 PSI
Flow rates at 10 Feet per Second
1/2" x .049 3.9 GPM
1/2" x .065 3.35 GPM
5/8" x .065 6 GPM
5/8" x .083 5.1 GPM
3/4" x .065 9.4 GPM
3/4" x .083 8.34 GPM
Depending on your skills and tool availability tubing cab be bent and flared or ORFS brazed on.
Thank you for the input. I do have bending tools and a flaring tool so I'll go that route. Wasn't sure how to go about it or what to use. You cleared it all up now. Better to ask a dumb question then spend a lot of money and aggravation doing something all wrong. I know how to machine but the tractor is all new to me and I don't want to screw anything up. Thanks again.
/ Rear hydro hook up #4
Jim,
only dumb question is the one you don't ask.
Roy
GEHL TELESCOPIC FORKLIFT (A65053)
GEHL TELESCOPIC...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
26 Gallon Dewalt Air Compressor (A65579)
26 Gallon Dewalt...
INSPECTION (A65583)
INSPECTION (A65583)
Anco 3Pt Ditcher (A66408)
Anco 3Pt Ditcher...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
