Rear Hydraulics Redux
   / Rear Hydraulics Redux #1
Jeff_Indiana
Stopped by the dealer today to discuss adding rear hydraulics today for my 970. (to run a top link hydraulics cylinder on a 3 pt hitch concrete mixer)
Dealer sez "Do you need to use the FEL and rear cylinder simultaneously"? I say no. He sez "Heck, if I were you, I wouldn't spend any extra money; just put a longer hose on the rear cylinder, unplug the bucket curl cylinder lines, plug in the rear cylinder and use the bucket curl valve to control the rear cylinder."
Sounds like a pretty good plan to me. In fact, other rear hydraulic uses I envisioned would work OK in this manner as well.
Anybody else face a similar situation with the same fix?
Jeff
   / Rear Hydraulics Redux #2
That is what I did on my 4300 for the angle cylinder on my rear blade. My new tractor ( 4520 ) ,that I should get Tuesday, has a diverter valve on it so I will have a set of connectors at the rear and for the FEL I also will have a third valve for the 4-in-1 bucket. I decided to spend the $$ as it became a pain to fish the hoses out of the way, clean the connectors, swap and somehow in the middle of the job I seem to always needed to use the bucket.
Your application may vary, professional driver in a fenced field, results may not be typical, it will take longer and they are watching you.
   / Rear Hydraulics Redux #3
The electric diverter (two more circuits) is salty. The third SCV isn't so bad -- 300-ish for a 4410, maybe about that for yours.
I would NOT do anything that would disable my FEL while using any other implement. I just cannot imagine being on my tractor and having a disabled FEL. To me, it would be like tying one arm behind my back -- I might be able to accomplish the task at hand, but it wouldn't be pretty!
Yeah, I hear ya; I'm concerned about disabling the FEL, and the hassle of swapping hoses. Actually, it is only one hose now I think of it; it's a single acting cylinder.
For the concrete mixer, however, I can't think of a reason I need to curl the bucket though. I can envision needing the loader to move the bags of concrete from truck to job, but I won't need to curl the bucket; it will be fixed in one place. (loader will still go up and down)
   / Rear Hydraulics Redux #5
I run a 2-way cylinder off the power-beyond circuit at the rear of my 970. I use it to tilt the BB. I've noted on this forum that JD has an optional 4 valve rear mounted configuration for the 870-1070 tractors. Don't know exactly how it's plumbed in with the SCV or if you have the power-beyond setup but it's out there. Was mentioned that the parts are becoming hard to find as well. Hope this helps. AKfish
   / Rear Hydraulics Redux #6
AKfish,
Can you post a picture of your setup and maybe part numbers? I would definitely like to have a setup similar to yours to rotate my rear snow blower chute!
Hypernix
Landoll Hauloll (A53472)
Landoll Hauloll...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
John Deere Z915E Zero Turn (A51573)
John Deere Z915E...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
