? Rear gearbox fluid
/ ? Rear gearbox fluid #1
Anonymous Poster
Epic Contributor
I have a "grey" Kubota B5000. I'm trying to find out what fluid goes into the rear gearbox, and to what level should it be filled? (There is a plug in the side of the housing approx. half-way up - looks like this would be the fill level?) I believe this would be the same fluid for the 3 point lift also.
/ ? Rear gearbox fluid #2
Yes, that is the level it should be at (hole in middle). I just got some sight-windows that screw into that hole, and I can visually check the level without having to remove that nut.
I got my Gear Box oil at Western Auto ( I think it's 80 or 90 W).
Regards,
Dave "Gatorboy" Hoffmann
Fallston, Maryland
/ ? Rear gearbox fluid #3
In my tractor(L3000), the rear axle/3 point and transmission is all hydraulic fluid. The front axle is 90w gear oil.Maybe its different for your tractor though.
Paul
Use a straight SAE 80 or 90 oil. Do not use hypoid or any oils with additives which create problems for your hydraulics.
/ ? Rear gearbox fluid #6
Hi ya
ya bring up a good point and one i'm trying to work out too most of the time ya see 80W (or there abouts)in gears ,diff's ,front axles,but not in hydros or 3 point ..even off the top of my head i can't recall puting that hevey oil in a back end before 10w or 15 w or uni oil yes many times but 80w for a hydro pump ?????????
catch ya
JD Kid
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A64556)
2016 Chevrolet...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2008 Chrysler Sebring Sedan (A64194)
2008 Chrysler...
