? Rear gearbox fluid
/ ? Rear gearbox fluid #1
Anonymous Poster
Epic Contributor
I have a "grey" Kubota B5000. I'm trying to find out what fluid goes into the rear gearbox, and to what level should it be filled? (There is a plug in the side of the housing approx. half-way up - looks like this would be the fill level?) I believe this would be the same fluid for the 3 point lift also.
/ ? Rear gearbox fluid #2
Yes, that is the level it should be at (hole in middle). I just got some sight-windows that screw into that hole, and I can visually check the level without having to remove that nut.
I got my Gear Box oil at Western Auto ( I think it's 80 or 90 W).
Regards,
Dave "Gatorboy" Hoffmann
Fallston, Maryland
/ ? Rear gearbox fluid #3
In my tractor(L3000), the rear axle/3 point and transmission is all hydraulic fluid. The front axle is 90w gear oil.Maybe its different for your tractor though.
Paul
Use a straight SAE 80 or 90 oil. Do not use hypoid or any oils with additives which create problems for your hydraulics.
/ ? Rear gearbox fluid #6
Hi ya
ya bring up a good point and one i'm trying to work out too most of the time ya see 80W (or there abouts)in gears ,diff's ,front axles,but not in hydros or 3 point ..even off the top of my head i can't recall puting that hevey oil in a back end before 10w or 15 w or uni oil yes many times but 80w for a hydro pump ?????????
catch ya
JD Kid
Toro Workman Utility Cart (A64194)
Toro Workman...
2003 40ft. Proclaim T/A Vacuum Tank Trailer (A64194)
2003 40ft...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
REDDICK 300 GALLON SPRAYER (A64278)
REDDICK 300 GALLON...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
