Rear Blade Advice
/ Rear Blade Advice #1
K10
NH
BX1500
I am looking for a rear blade for my BX. I will need it for FEL ballast, snow removal and light dirt and gravel grading. Woods makes the RBC series for the BX but they are expensive ($495.00 for a 60"). Land Pride has the 15 series and the 05 series. The 15 is about the same price as the Woods but with a higher moldboard and about 60LBs heavier. The 05 series seems light by the specifications at nearly 110LBs lighter than the 15 series and 50LBS lighter than the Woods. The 05 is still $405.00. TSC makes a 5' for $299 and it weighs the same as the Land Pride 15 series. On its price and spec, TSC would seem like the better choice. Your thoughts, experiences and advice. Thank you.
/ Rear Blade Advice #2
I have the RB15 and love it, it does seem lite but so far it has been heavy enough to use as ballast with the FEL. Right now I use it to level and maintain my driveway and it does a pretty good job and leaves a nice finish. I will be using it this winter to aid the FEL with snow removal and am pretty sure it will be adequate for ballast cause it worked with a bucket full of wet dirt.
/ Rear Blade Advice #3
As much as I like Land Pride, for your uses, I would go with TSC from the sound of your needs. Be sure it has a removable cutter edge.
/ Rear Blade Advice #4
I have that 5' blade from TSC. The orange, XB model, since I had a BX at the time. I'll use it with my B2320 this winter.
The edge is reversible and it has 5 angle positions. Frankly, for all it has to do, it has worked just fine. That it is affordable, is fine by me.
/ Rear Blade Advice #5
I went with the Woods RB60 primarily because it had tilt as well - but I have never really used it....:D
The TSC model would have served my purposes well
I do suggest getting skid shoes - not sure it they can be added to the TSC model
/ Rear Blade Advice #6
Check how well design,by that I mean re enforce/support also thickness of steel used.
/ Rear Blade Advice #7
I got lucky, I bought a 60" blade on craigs for 100 bucks. Looks like bp's, but it is heavier steel and is red. The guy I bought it from has a B7800, had just asphalted his drive, and did not need it anymore. He told me that he bought it at the local Kubota dealership. Replaceble cutting edge and all. I think it is a Bush Hog? FWIW my ballast box full of rocks is much heavier than my BB. I usually put that on for heavier fel work. We'll see this winter as this is my first with this tractor.
/ Rear Blade Advice #8
I may add , also consider getting a rubber cutt[ng edge vs shoes for your BB, works very well in the snow, like a squegee.
/ Rear Blade Advice #9
A friend of mine who plows snow with his truck uses a piece of PVC pipe that he split and covers the cutting edge of the plow with , I have not tried this method yet but he swears by it .
/ Rear Blade Advice #10
From the looks of it the $299 model blade at TSC is designed for full size Cat-I hitch and may be too tall for the BX to lift high enough. They also sell the same blade you see in BP fick's photos for $319.
In any case I think it would work fine for what you describe. In the winter you will not have nearly enough traction to do any damage to either of these blades. You might want to add chains to the rear tires. I have plowed snow with and without chains and the and chains will put your tractor into a whole different class when pushing snow. It is money VERY WELL spent.
/ Rear Blade Advice
Thank you. I like the curve of the blade on the Woods RBC series but for $200 less, I will take a hard look at the TSC XB model.
/ Rear Blade Advice #12
Rhino makes a nice RB #200 that is light duty and easily fits the BX. However I traded it in for a Rhino #300 that tilts and is 100 lbs heavier. It lifts just fine but just barely fits on the lower arms. The weight and the tilt allows me to do more ditching and scraping. The price is average from a Dealer.
/ Rear Blade Advice #13
I have one of the TSC rear blades on my BX and it works great.
/ Rear Blade Advice #14
I wished you were closer to me ,I'd give you a good deal on a woods rb60 that a friend gave me . He bought a 58hp JD and it came with it, to small for him. He got a bigger one. I need a 6' not a 5' so am looking to trade it or sell it ,only used a few times and is in great shape,just some surface rust. I really don't know what to ask for it,$ wise.
/ Rear Blade Advice #15
Whichever model(s) you gravitate toward, I would suggest keeping an eye on Craig's list. There are 3 available within 50 miles of me for $250.00 or less in good shape.
/ Rear Blade Advice
I have been looking on craigslist for about a month now but have not seen anything that is worth going after to this point. I will continue to poke around.
/ Rear Blade Advice
There is a Bush Hog blade available on Craigslist. Any opinions on Bush Hog? It is a new unused 20-06 model. For a 6' blade at 164LBS it would seem rather light. Some of the other 5' models are 80LBS heavier.
/ Rear Blade Advice #18
You're right about waiting to find one with more weight, since all the downforce on the TPH is going to be a product of the weight and front to back length of the implement. Couple a good, hefty blade with a set of chains, as easygo suggested, and you should be ready to handle a decent NH snowfall and also do some earth work when it gets warm again.
-Jim
/ Rear Blade Advice #19
I have the TSC county line 60" (dark yellow, not the orange XB) and used it with no problems on my BX 24. It seemed heavier built than the XB. It does a great job plowing in heavy snow - especially with chains on the rear tires. With the top link shortened it will lift the bottom of the blade to about a foot off the ground (when I first put it on the top link was extended and it only went up about 3 inches).
1988 BOMAG BW-213PDH-2 SHEEP FOOT ROLLER (A67714)
1988 BOMAG...
2025 Swict 84in Bucket Skid Steer Attachment (A66734)
2025 Swict 84in...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
2018 PETERBILT (A68134)
2018 PETERBILT...
ALUMINUM HYDRAULIC TANK (A68842)
ALUMINUM HYDRAULIC...
