RE213475 sensor
   / RE213475 sensor #1
tervete
Martintown, ON, Canada
JD 3320
HI, I can't get get the pedal sensors within specs. Does this mean the sensors need replacement?
   / RE213475 sensor #2
Maybe you could embellish your request with more informative info.
   / RE213475 sensor
My Released Position Signal Voltage is 0.6 volts. normal specs are between 0.6-0.9 volts.
My Pressed Position Signal Voltage is 3.9 volts. normal specs are between 2.7-3.5 volts.
   / RE213475 sensor
I am getting errors 01 and 02 while driving. I went into the diagnostic mode and found the voltage on the pedal sensors are out of range. I tried for a while and the best I could get are values mentioned above.
   / RE213475 sensor
I installed a foam stopper to shorten the pedal travel which enabled me to get the sensors within specs.
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
1261 (A50490)
1261 (A50490)
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
