Re-useable hose ends
/ Re-useable hose ends #11
The reusable hydraulic fittings are handy to have around if you have the correct hose size and type of hose. They are also good for making up a test hose for a project. If you are putting a piece of equipment together, you can hook things together to see if the project will work, before you finalize your design. I think that most of you know to leave some slack in the hose, so it will not destroy itself, and or the fittings.
They are more expensive then regular fittings, and you don't want know how much a SS fitting cost.
Reusable SAE 100R2AT Hose Fittings > Discount Hydraulic Hose.com
http://www.hydraulic-supply.com/com...ion=&functionid=web.prod.browse&NumSelected=3
Toro Timecutter Max (A61166)
Toro Timecutter...
Attention (A57148)
Attention (A57148)
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
Giyi SE61 QA Broom Sweeper (A60463)
Giyi SE61 QA Broom...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
