Who Makes Their Own Hoses?
   / Who Makes Their Own Hoses? #21
I have about 30 of the SC 2 wire JIC connectored ones in service. Not a single failure even though I have subjected 3 of the 3/8" ones to pressure sufficient to blow up 4 bucket cyls on the 7520. Depending on the yield strength of the 3/16 wall cylinder tube, expansion of the steel would require a hydraulic pressure of 12,000 PSI minimum. -- What is your criterion of pretty crappy?
Fitting quality. I cracked one fitting putting it on and I have put hundreds of hydraulic fittings together.
On my micro ex the thumb hose broke 3x from physical(in about 1yr) abuse until I went to a parker brand hose. That parker hose hose has been on there for 2yrs now. This parker hose is really the only one that isnt a surplus center or some other cheap chinese hose.
   / Who Makes Their Own Hoses? #22
I make my own hoses. For obvious reasons, they always break when you need them so the investment is worthwhile. My tractor is all hydraulic and I am often using it when shops are closed.
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
ALLISON TRANSMISSION (A55745)
ALLISON...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
