Re-purposing 1965 Pontiac GTO To 2004 Mahindra 3015
   / Re-purposing 1965 Pontiac GTO To 2004 Mahindra 3015 #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Can you believe I actually had tire chains for my GTO? Had to remove a few links.
   / Re-purposing 1965 Pontiac GTO To 2004 Mahindra 3015 #2
Believe that you did have them? No.
Believe that you still have them and could find them? Not so much...
   / Re-purposing 1965 Pontiac GTO To 2004 Mahindra 3015 #3
Trying to invision in my head chains on a GTO. :eek:
Good you found some use for them.
Do you still have it ?
   / Re-purposing 1965 Pontiac GTO To 2004 Mahindra 3015 #4
I my self am not surprised. In the good old days most every thing was rear wheel drive instead of front wheel drive. Yes, 4 wheel drive existed for pickups, but was not near as common as today. Weght,studded snow tires and chains was the answer. You take a little old 1/2 ton 2 wheel drive pick up and boy you had a squirrelly mess on snow and ice. I new a guy that had a set of chains for a Ford galaxy 500 that he used to get back and forth to work when weather was bad. So yeah, chains back in the "good old days " is not that surprising to me.
Had them hanging on the wall behind my air compressor. Just never could pitch them thinking that maybe some day........
That's it in a nutshell. When your only vehicle is a 1965 GTO and you have to get to work in the snow you put on chains. Doubt that I used them more than once or twice, however.
Had to take off the racing slicks to run tire chains. Would have been all of twenty years of age at the time.
   / Re-purposing 1965 Pontiac GTO To 2004 Mahindra 3015 #7
I'm not thinking of the days when we bought a car we actually used it.
   / Re-purposing 1965 Pontiac GTO To 2004 Mahindra 3015 #9
Disappointed, from the title, I was expecting to see a V8 Mahindra.:(
Maybe he has an old 389 tri power laying around too!
Make that loader really work wouldn't it?
Haha--It wasn't the three deuces just a Carter AFB quad if I remember correctly.
I now drive an old 2008 Cadillac STS which puts out the same 320 HP as the 389 in the GTO but does it with a hundred less cubic inches of block. Not bragging on the Caddy, it's an electronic nightmare.
My wife went to start it a while back with the keyless pushbutton and the battery didn't have quite enough oomph to satisfy the crankshaft sensor so it just kept cranking itself until the battery died. Put in a new battery and then found out that the long cranking had ruined the starter which is located under the intake manifold and cost $600 to replace. :)
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2011 Mitsubishi Outlander AWD SUV (A51694)
2011 Mitsubishi...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
