Re: JD 2320 Idle
/ Re: JD 2320 Idle #1
MacTractor
New Brunswick
2008 JD 2320
Re: JD 2320 Idle
For those 2320 owners out there, when you pull the throttle back to the idle position, what RPM does your machine idle at?
Cheers,
/ Re: JD 2320 Idle #2
Re: JD 2320 Idle
Mac
My idle varies and I don't know why. Almost all the time it is just a shade above 1300. Every once in a while, mostly when it is really cold. it idles right at 1500.
/ Re: JD 2320 Idle
Re: JD 2320 Idle
Thanks for the reply,
I am finding mine will not really settle down below 1500 RPMs and was trying to figure out if this is normal. I will check the throttle control and see if I can find what the proper RPM is and look to adjust.
Cheers,
Mac
DYNAPAC CP-2700 PNEUMATIC ROLLER(INOPERABLE) (A67714)
DYNAPAC CP-2700...
2003 Johnson 50hp 4-Stroke Outboard Boat Motor. (A66738)
2003 Johnson 50hp...
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
JOHN DEERE 5090 EL TRACTOR (A65057)
JOHN DEERE 5090 EL...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A69167)
2001 FREIGHTLINER...
2017 Ford Escape SUV (A66738)
2017 Ford Escape...
