Re: JD 2320 Idle
/ Re: JD 2320 Idle #1
MacTractor
New Brunswick
2008 JD 2320
Re: JD 2320 Idle
For those 2320 owners out there, when you pull the throttle back to the idle position, what RPM does your machine idle at?
Cheers,
/ Re: JD 2320 Idle #2
Re: JD 2320 Idle
Mac
My idle varies and I don't know why. Almost all the time it is just a shade above 1300. Every once in a while, mostly when it is really cold. it idles right at 1500.
/ Re: JD 2320 Idle
Re: JD 2320 Idle
Thanks for the reply,
I am finding mine will not really settle down below 1500 RPMs and was trying to figure out if this is normal. I will check the throttle control and see if I can find what the proper RPM is and look to adjust.
Cheers,
Mac
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
2012 CHEVROLET SILVERADO 1500 (INOPERABLE) (A67714)
2012 CHEVROLET...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
PALLET OF ALUMINUM PIPING (A67714)
PALLET OF ALUMINUM...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
