Re gen cycles
/ Re gen cycles #11
I ordered a Yanmar YT235C it is a tier 4 when the
light comes on the dash just pust the button to re-gen
and keep going no need to stop
willy
/ Re gen cycles #12
I'm assuming you have the idle set high, even when not working?
On my LS, if I run at 1600-1800 RPM, I regen about every 30 hours. If I run at 2200-2400 RPM, it's >50 hours to regen, but the LS forces into regen at precisely 50 hours. I live in a cool climate as well.
Usually 1800-2400
/ Re gen cycles #13
If you can check out this tractor:
Its when you think you are saving on fuel by
running with low rpm's that gum up the works!
That's what causes you to re-gen more often!
I will not be having a problem like that as when
I will be using the attachments they require the
pto to be used and it requires 2600 rpm's and I
don't expect I will have to re-gen very often!
And when I do re-gen I can just push a button
and keep on working so no need to stop for 10
minutes or more. Yanmar has this one figured
out. Why some of the other diesel tractors have
to stop and re-gen is nothing but a PITA! When
people are working with their tractor they don't
want to stop in the middle and go to some place
that won't catch on fire!
willy
/ Re gen cycles #14
If you are looking at a "Used" L3540,the don't have the pollution controls.I have a "40" series tractor.
/ Re gen cycles #15
If you're getting on and off your tractor a lot, and you're used to pulling it down to an idle (either by foot control or by hand throttle), getting off, doing your work, jumping back on, revving it up and moving, rinse and repeat, then you will need to change your habits. You're new idle should be much higher when doing the on/off thing.
My absolute idle is under 1,000RPM for my tractor. That's the hand throttle pulled all the way down. The ONLY time it is at that idle is when I am warming it up, or cooling it off (turbo). And that is for a few minutes or sometimes, seconds. (Yes, I did say seconds. When its 90 degrees out, it does not need to warm up at idle for more than a few seconds before bumping up RPM)
After the engine has warmed up a bit, I use the hand throttle to bump up the RPM to no less than 1500RPM. That is my new idle. The tractor does not go below that until I cool it off at the end of work. This goes for the 10 minute jobs, to the 18hr jobs.
I did have a hard time with this concept when I first got my tractor. Being a gear tractor, I would use it like an old farm tractor I used to have, when using the FEL: Hand throttle pulled all the way down at absolute idle. Use the foot throttle to raise and lower RPM while doing FEL work. I learned that this rapid change in acceleration of the engine combined with running at absolute idle, is one of the worst things you can do with a tractor equipped with a DPF (besides postponing the regen and building up too much soot, resulting in limp mode and a dealer call). I had to retrain my brain, to use the hand throttle set at 1500, and use the foot sparingly. I still get the work done, but its just different.
As I said before, it is what it is. If you dont want this EPA garbage, then you will need to find an older used tractor. You wont have the annoyances of the DPF and regen cycles, but who knows what else you will have. I guess the same could be said for a new tractor, given the issues, recalls, and warranty work on top of the annoyances a DPF brings. But at least you will know the history of the tractor first hand.
this came up before and a comment was made that running at that high rpm was ...i think disconcerting?
the reply was....get used to it.
i now operate as above although i've noticed my gas mileage.....ain't what it used to be.
Run the he// out of it, it's kubota!
/ Re gen cycles #16
Using much more fuel somehow appeases the pollution gods? Somebody 'splain that to me.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2019 PETERBILT PB520 GARBAGE/SANITATION TRUCK (A59823)
2019 PETERBILT...
Great Dane Van Trailer (A61307)
Great Dane Van...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2020 DRAGON ESP...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
