Re-establishing Survey Corners and Way Points?
   / Re-establishing Survey Corners and Way Points?
No... thank you taking the time to post as your posts have taught a lot over the years.
Current surveys often affix a metal tag to any protected tree and we'll documented along with topography...
Many a new home construction or addition have been stopped cold due to an existing oak tree... depending on diameter ANY tree is protected except Eucalyptus and Monterey Pine...
I wish I had a way to scan full survey ad lots of good info... also plot plan shows corner of house with exact distance to line which matches my far gate post.
Long ago I have made it standard practice to enhance any survey markers on property I'm associated with...
The Nail with Shiner in street which I own half off would have had my roto hammer drill and at least a 36" foundation stake...
Please come back and tell us how it went! :)
I've mentioned before - A broker listed the empty land next door using my postal address. He refused to revise the listing.
Until I told him that everyone who pulls into my driveway will be told my place isn't for sale and the listing in MLS is from a scammer who will take their deposit and disappear.
That got him going. He went back to the county assessor and was issued the next postal address for his vacant land.
Will do... I expect it will closed with new owners in 30 days...
My offer was 940k with the brother being able to rent back in the contract... in other words nothing really would have changed and he could continue where he was for 43 years with his dogs.
   / Re-establishing Survey Corners and Way Points? #43
Remember that your property may have been originally just set up with chains and stuff. Does new tech make things better? Or do you have to redefine the borders to a more clearer division of property. This is a very messy area, legality, and open to interpretation and open to contention with more exacting measuring methods. 10 feet, can sometimes be important. If you own 20 or more acres it can be hard to monitor this, if you also have a 9 to 5 job. I have found that all my neighbors have made inroads into my property, and I called them on that, and they backed off. Yet, they still did it. It is not a nice world out there. I just don't like any of my immediate people anymore.
   / Re-establishing Survey Corners and Way Points? #44
Neighboring parcel is for sale for the first time since 1955 to settle the estate and there appears to be confusion among the prospective buyers and agents as to the location of our shared property line...
I have not been able to find the pins shown on my property's 1989 survey...
The street has been repaved and 5 years back the city dug up and replaced city sewer line running under shared property line taking out the pins.
Realtor suggested a survey of the property for sale and wants me to participate which I declined.
I got to thinking wouldn't it be much less expensive avoiding the cost of a survey calling the original company out to find the pins?
Any tips on how to approach the survey company to find three pins on a straight line?
A new survey here tends to run about 5k.
Is the best shot sticking with the original surveyor to save on cost?
All land surveys should be registered with the county assessor. The last survey map should be on file with the county.
   / Re-establishing Survey Corners and Way Points? #45
Perhaps in an area where "lot size" is smaller - ultra runner. Here where I live - lot size is measured in hundreds - even thousands - of acres. My 80 acres is a mere pimple on the landscape.
In my 40+ years out here I've never been approached to share in the costs of any surveys. Even though these surveys established three of my four corners by modern survey methods.
The 1892 government survey was/is just fine by me. For that matter - most all the larger plots were the result of long past government surveys. Homesteads ...........
In the central/western US, the government conducted General Land Surveys under the modern township/range/section system. They are pretty accurate. But in the eastern US, those original surveys were done under the “meets and bounds” system. And those old surveys are often not useable today. Those surveys talk about corners starting at: the large oak tree, black rock, stream meander, etc…. I suspect that is the situation that the OP is dealing with. Unless those old meets and bounds surveys are refreshed with modern surveys and records, it’s often not possible to determine the true property boundaries.
   / Re-establishing Survey Corners and Way Points? #46
Can you rent survey grade GPS? Yes you can. Would you be able to run it? No.
How about renting GPS gear - or something - more precise than what's in a phone or cheap Garmin?
Using those amateur tools, and scaling off the 1905 subdivision map and the county assessor version of it, the indicated back corner points are all within a 30 ft circle. Within the circle is the only Redwood tree in the region.
Grandpa had a mining engineering degree, and career, and did years of mining surface and underground survey work. Then after his retirement one neighbor told me they worked together to set monuments along their shared line that 100 years ago divided an existing orchard. I suspect but can't prove, that Grandpa planted that Redwood as a back-corner monument that could be seen from a distance. (It's down in a jungle of blackberries and poison oak in a steep ravine, so I won't look for a pin using metal detector until I have a better clue of where to look).
Is there some simple solution more precise than the phone and Garmin?
Maybe I should just hire the surveyor who set the recent (2010) known back corner pin, to come and monument this other back corner.
   / Re-establishing Survey Corners and Way Points? #47
That could be your least expensive solution, especially if your time is better spent elsewhere. We've rented and older survey grade GPS for a project ...carving out 12-20 acre parcels from a larger tract The front pins were set. I had to establish approximate points where the rear line would go, turn in the data, then they corrected so that we could go out and put in the side and rear lines.
Which leads up to an off topic tale which I've always found comical...
It was about this time of year when I drove up a woods road to GPS the last points. I hiked in, did what I had to do, and returned to the truck at about lunchtime. On the way out I got behind a grader operator who was plowing the road. I waited for him to let me past but instead he stopped and got out his lunch. This seemed like a good idea so I did the same, although rather curious why he didn't let me go by.
Suddenly he jumped up in the cab of the grader and started dancing, apparently to some song on the radio. I don't recall what happened next, all that I can remember was being awestruck that the old French Canadian was still able to dance... in the cab of a grader, no less! :D
   / Re-establishing Survey Corners and Way Points? #48
Eddie Walker recently posted a similar question on some kind of app or method to build a fence to line when you can’t see between the corners. There are ways but generally it’s not easy unless you have some equipment and know what you are doing.
One thing to understand is gps degrades in heavy tree cover. In thick trees even the survey grade stuff won’t work.
   / Re-establishing Survey Corners and Way Points? #49
The short answer is that more accurate GPS gear is expensive.
If you can't get it figured out with some of the low tech methods above, I am with @Jstpssng that getting the prior surveyor back is probably the least expensive choice.
If your grandfather was a sensible sort, and it sounds like he was, then I bet you are right that the "odd" redwood was there intentionally.
If you really want to have fun; here is a remarkable treatise on how Romans did surveying to high accuracy, including surveying aqueducts underground.
All the best,
Peter
   / Re-establishing Survey Corners and Way Points? #50
The Trimble GPS system we bought before I retired was around $60,000.
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
