Re - Caps ? Anyone run them?
/ Re - Caps ? Anyone run them?
I.m still wondering ... some of you have shared "when my dad" ... this is 2011 are they any better and would you run them in todays world on your farm pickup truck ...
/ Re - Caps ? Anyone run them? #32
I used to use recaps when I was younger and did not have problems with them, but they were on a VW beetle so not much weight. I have not tried to find recaps for pickups so I'm not even sure they are available around here. But, to answer your question as to what I would do:
Pickup truck limited to ranch - Yes
Pickup truck on highway - No
Car - No
Peterbilt dump truck - steer axle - No, drive axle - Yes.
/ Re - Caps ? Anyone run them? #36
Duffster said:
Regrooved and Recapped are not the same thing.:thumbsup:
Pretend that I'm unschooled.. What is the difference?
/ Re - Caps ? Anyone run them? #39
Retreaded means manufactured by a process in which a tread is attached to a casing.
Part 571.117: Standard No. 117; Retreaded pneumatic tires. - Federal Motor Carrier Safety Administration
Regrooved:
c) Regroovable tire means a tire, either original tread or retread, designed and constructed with sufficient tread material to permit renewal of the tread pattern or the generation of a new tread pattern in a manner which conforms to this part.
(d) Regrooved tire means a tire, either original tread or retread, on which the tread pattern has been renewed or a new tread has been produced by cutting into the tread of a worn tire to a depth equal to or deeper than the molded original groove depth.
This is in Part 569.
/ Re - Caps ? Anyone run them? #40
Duffster said:
Well so am I so that would be like the blind leading the blind. :laughing:
I got the dark sunglasses and Ronny Milsap lives about 30 minutes up the road.. Does that count?
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2015 Dodge Journey SXT SUV (A59231)
2015 Dodge Journey...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
