rattle at idle?
/ rattle at idle? #1
BiXLL
After first mowing of the year, which the 1042 did a great job with its new Gator blades, when I shut the mower deck down and was just sitting there, it was making an extremly loud rattle. I mean it sounded like something was going to fly off! It runs fine, mows fine, just makes that rattle at idle, any ideas?
/ rattle at idle? #2
Is the rattle with the deck engaged or disengaged? This could be a spring loaded tensioner banging/jumping.
Joel
/ rattle at idle?
Joel
It is with deck disengaged
/ rattle at idle? #4
i have a 1042 mine rattles at idle also. the heat shield on the muffler is what it was on mine. you might want to check there.
/ rattle at idle? #5
Good call on the heat shielding. I know the pc that covers the header pipe on my 2544 wiggles pretty good at idle even though it's screwed tight.
Joel
/ rattle at idle?
I will check it out later today, Thanks!
/ rattle at idle? #7
BiXLL where did you get the gator blades for your 1042 and how much $ was they. i would like a set for my 1042.
/ rattle at idle?
From the post I got when I was searching for them..
Try Jackssmallengine site....jackssmallengine.com
Jacks site for the blade is about $12 and his shipping is about the lowest.
His site also has all the dimensions listed.
After some checking, the 1042 uses the same blades as the 2542, which I have.
The 3in1 mulching blade listed in the manual has been updated to 759-04081.
/ rattle at idle? #9
so did you get Part# 91940
/ rattle at idle?
I don't remember, but it sure looks right to me!
(2) for 42" cut on lawn tractors Cub Cadet 742-3018
759-3824 21 1/4" 3/4 5/16 2-1/2 .300/.203
Part# 91940
Regular Price:$18.24
You save 30% !!!
Our Price: $12.77
Cub Cadet XT1 Riding Mower (A66285)
Cub Cadet XT1...
Informational Lot - Financing (A63689)
Informational Lot...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
