rattle at idle?
/ rattle at idle? #1
BiXLL
After first mowing of the year, which the 1042 did a great job with its new Gator blades, when I shut the mower deck down and was just sitting there, it was making an extremly loud rattle. I mean it sounded like something was going to fly off! It runs fine, mows fine, just makes that rattle at idle, any ideas?
/ rattle at idle? #2
Is the rattle with the deck engaged or disengaged? This could be a spring loaded tensioner banging/jumping.
Joel
/ rattle at idle?
Joel
It is with deck disengaged
/ rattle at idle? #4
i have a 1042 mine rattles at idle also. the heat shield on the muffler is what it was on mine. you might want to check there.
/ rattle at idle? #5
Good call on the heat shielding. I know the pc that covers the header pipe on my 2544 wiggles pretty good at idle even though it's screwed tight.
Joel
/ rattle at idle?
I will check it out later today, Thanks!
/ rattle at idle? #7
BiXLL where did you get the gator blades for your 1042 and how much $ was they. i would like a set for my 1042.
/ rattle at idle?
From the post I got when I was searching for them..
Try Jackssmallengine site....jackssmallengine.com
Jacks site for the blade is about $12 and his shipping is about the lowest.
His site also has all the dimensions listed.
After some checking, the 1042 uses the same blades as the 2542, which I have.
The 3in1 mulching blade listed in the manual has been updated to 759-04081.
/ rattle at idle? #9
so did you get Part# 91940
/ rattle at idle?
I don't remember, but it sure looks right to me!
(2) for 42" cut on lawn tractors Cub Cadet 742-3018
759-3824 21 1/4" 3/4 5/16 2-1/2 .300/.203
Part# 91940
Regular Price:$18.24
You save 30% !!!
Our Price: $12.77
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2022 EZ-GO ELITE...
2018 P.J. Trailer Trailer, VIN # 4P5F82023J1283348 (A65563)
2018 P.J. Trailer...
Gravity Flow Wagon (A64127)
Gravity Flow Wagon...
